Sony KDL-55ex720 tab bond problem and TCON?
  • curt2199
    • Oct 2013
    • 54
    I picked this TV up for free and the person admitted to spraying the screen with windex which then cause this problem. There were just a few lines but removing the bezel and frame caused more to pop up. I discovered that the yellow ribbon cable has separated and putting pressure on it cause almost all the lines to go away leaving what you see in the picture. I have since cleaned up all the corrosion caused by the windex. When pushing on a different yellow ribbon the large vertical bands go to one solid dark color but they never disappear so I'm wondering if the windex shorted a connection and cause the TCON to go bad as well?
  • budwich
    • Jul 2015
    • 3097
    Re: Sony KDL-55ex720 tab bond problem and TCON?
    those connection ... if they are still like that, need more cleaning... severely but gently... :-)
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4541
      • Italy - Milan
      This tv needs about a magician to turn back to the early days... no damage to tcon..
        You need good magnifying glass to inspect the boding and the copper traces to see if any conductor got eaten sway or not, and yes, it needs really good cleaning.
        • curt2199
          • Oct 2013
          • 54
          Yep, I cleaned the corrosion off with a fiberglass brush. The some of the conductor got eaten away that wasn't under the yellow ribbon attached to the board. At this point the biggest issue is the yellow ribbon itself requires pressure on it to keep the lines from showing. It appears it itself has separated.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4541
            • Italy - Milan
            I think you can do anything because if you have to press on the tab, the tab itself is damaged, so you have to jump over the corrosion on th tab, but on the tab you can't solder with tin, only with silver paint, but there are too much traces damaged..
            • curt2199
              • Oct 2013
              • 54
              Actually it's not the tab. I have to put pressure in the middle of the yellow ribbon because there is a clear separation between the two layers of the ribbon as I can see the gap. If I push the two layers together then most of the lines go away. I was trying To come up with some sort of adhesive that I could use to seal the two ribbon layers back together but wouldn't be conductive shorting the traces in the ribbon.
              • curt2199
                • Oct 2013
                • 54
                I also tried hearing the cable to see if it would self-stick back together but that didn't work.
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  You probably dont want to hear this but you wont be able to repair this
                  There are places that will rebond the tabs but at a cost of over $300 , for the age and size probably not worth it
                  • curt2199
                    • Oct 2013
                    • 54
                    Yeah I figured as much. It was free so was just hoping I could make it work. I'm not ok t anything and I'll pull the boards and put them on eBay.
                    • Ashg
                      • Apr 2021
                      Styrofoam to add pressure on the card.
                      • Daren87
                        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                        by Daren87
                        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                        08-13-2023, 03:25 PM
                      • iglitare
                        by iglitare
                        09-04-2025, 07:13 AM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • rimwall
                        Sony KD-65x7500D - double image - Tcon or Panel?
                        by rimwall
                        This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                        I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                        11-18-2025, 02:09 AM
                      • thelankanguy
                        Sony KD-55X9000F TCON Issue
                        by thelankanguy
                        The TV shows a black screen with no image.
                        TCON ribbon connectors were disconnected individually for image and there was no half image even.
                        Later both ribbons were disconnected and TCON voltages were tested.
                        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                        There is also a short to ground in this circled inductor.
                        Is this a TCON issue or something else ?...
                        12-13-2024, 12:27 AM
