chances of reviving a Philips plasma tv?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: chances of reviving a Philips plasma tv?
    Originally posted by kikkoman
    i found out the model number. they're 42PD1609 's - professional units (no tv tuner, just monitors) and most likely come from an airport. this probably means they're somewhat burnt in.
    guess i'll back out.
    thanks for your replies though.
    we got some plasma monitors in for service that were lesss than a year old.
    they were brought in by a maintainence contractor.
    when i told him that i had the monitors from dayton international airport ready for pickup he asked how i knew that.
    real nice burnin of logo and other fixed text.
    the ones you mention were likely rode hard and put away wet.
    if free go for it.
    • i4004
      • Oct 2006
      • 2029
      but what is the overall state of plasma burn-in these days?
      i mean is the technology progressing at all?
      • Wizard
        • Mar 2008
        • 2296
        No change in tech on plasma panels. They burn as CRT do.
        Cheers, Wizard
        • Krankshaft
          • Jan 2007
          • 2328
          As far as burn-in is concerned will a plasma burn-in faster than a CRT?
          I've only managed to burn in one CRT I have it was because for years I didn't adjust the vertical and horizontal controls. So the image never reached the end of the screen when I finally adjusted the controls I saw the burn-in.
          Well the phosphors that weren't excited throughout the life of the monitor .
          • Wizard
            • Mar 2008
            • 2296
            Your questions is not clear cut as you think. Too high settings or set up right and sitting in same spot too long is what u get. Set up right and keep image dynamic and no steady stuff too long even every few hours is sufficient.
            The good practice is keep contrast/brightness DOWN yet maintain good pic. They were set up in torch mode on all CRT based and plasma stuff.
            Plus keep image moving if cannot let it blank out like the airline stuff or blank the pic after a period of time.
            My CRT monitors never had blanked or put to sleep because I set the brightness/contrast lower yet good image quality as I have stated, so no burn.
            DLP, LCD and like don't have the kind of issue but HID lamps do lead shorter life if running too powerfully and is controlled how much power it is lit up via brightness control in user settings and turn it down a bit will extend the lamp long way. LCD not very much on their lamps, 60%-80% should be sufficient yet to keep them hot but not so overdriving or under driving them.
            Cheers, Wizard
            • i4004
              • Oct 2006
              • 2029
              #26
              eh..have you ever seen channel logo burned in the screen with crt?
              crt will eventually burn, sure, but plasma seesm to burn much faster...
              • dan8139
                • Jul 2004
                • 57
                #27
                Speaking of channel logos, etc, just WHY?!?!?!? I mean, people KNOW what channel they're watching don't they? It seems stupid to me.
                • celiabrown
                  Issue with Plasma Philips 37inch chassis FTL2.1
                  by celiabrown
                  Hello guys,
                  My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                  Can someone has any symptom like this ?
                  Thanks​
                  05-09-2024, 10:56 PM
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  Today, 03:43 AM
                • aidanmo
                  Philips 43PUS7506/12 - Loud blown out sound
                  by aidanmo
                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                  • Using the internal speakers, it always happens.
                  • Using the headphone jack, it never happens.
                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                  02-28-2025, 03:13 PM
                • ArMaaN376
                  Samsung PS51E550 Plasma TV
                  by ArMaaN376
                  I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                  Opened TV cover & observed foll
                  a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                  b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                  c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                  How to confirm Y -Buffer board...
                  06-19-2024, 04:05 AM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
