chances of reviving a Philips plasma tv?
  • kikkoman
    • Jul 2007
    • 691
    hi guys
    i have the chance to get 1 or 2 philips 42" plasma tv's. i'm currently trying to find out the model number(s) and if someone has attempted to fix them before.
    according to the seller they show the picture for 1 or 2 seconds when turned on and then go dark.
    he's asking 60€ apiece so if there's a chance of reviving them i'd be definitely in.
    IIRC there was something about a recall of some of their 42" and 50" sets a while ago (due to bad caps???)
    any help appreciated....
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: chances of reviving a Philips plasma tv?
    Philips/Magnavox LCD's are now made by Funai who seems to also be (directly or through subsidiaries) the OEM behind all the Walley World (Walmart), CostCo, Best Buy, Circuit City, and such "House Brand" TVs.
    A lot of boards are common between the 'brands' which makes them more readily available.
    I have an Emerson 19" LCD TV (Funai) out in the shop I haven't gotten too deep into yet. That one blows the fuse straight away. [I ran out of fuses,,, which wasn't hard because I only had one spare on hand in that size..]
    It has crap brand caps but none bloated. That one is almost new. Mfr date April 2008.
    Been working on an Element 22" LCD TV (Funai/Circuit City OEM I think but not sure) that won't stay on for more than 10 seconds. Same-same, it has crap brand caps but none bloated. It goes COMPLETELY dead. Not just video or back light, power light goes out too vice just flashing some odd color like the 'usual' problem they have. I suspect an IC in the PSU section is bad but I haven't started desoldering and checking yet.
    - This one is cream of the crap. PSU PCB is marked for 2 fuses but those positions have jumper wires where the fuses should be. DANGER! WILL ROBINSON!
    So far as what to expect...
    My guess is it will be more involved than just caps.
    Even still, even if you can't fix them...
    If the LCD's themselves are good then just those sold alone may be worth more than the whole TV as broken. - So before you tear it down get a quick snap shot of the screen working [for your ad] in case you don't feel like putting it back together later on.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Oops...
      http://www.funai-corp.com/support/default.aspx
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I guess the Element isn't much older. August 2007.
        - Dr Seuss
        • kikkoman
          • Jul 2007
          • 691
          it's not an LCD, it's a plasma.
          form what i've read so far it uses a Digitalview controller board () which works with plasma and LCD units, so issues might be similar to those with LCDs. just guessing here.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I've looked up the main board for various LCD TVs and found there are plasma's they also fit. I don't think LCD vs Plasma makes a lick of difference in the video sections other than maybe in the inverter.
            [I'm just guessing too.]
            MOST of the problems will probably be in the power supply section anyway and I know the PSU's don't care what kind of screen is out front. Compared to PC SMPS they are pretty simple. In them I'm seeing a lot of GP caps where low ESR caps should be used. [In odd-ball brands I've never heard of too. Some are funny: "Decon", "Procon" - Rat Poison and a Professional Con.]
            Anyway,
            For those that I've been able to find specs on, Panny FC easily exceed the original specs.
            Decent caps won't be hard to find for them.
            - Dr Seuss
            • Wizard
              • Mar 2008
              • 2296
              most common issue is blown YSUS. Usually best to change as as set on YSUS, and logic board, both upper and lower YSUS driver boards. Not very much bucks if it is V7 LG panel and it is a kit.
              Cheers, Wizard
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                wassa YSUS Wiz?
                - Dr Seuss
                • kikkoman
                  • Jul 2007
                  • 691
                  i hear philips offers repair kits, so i take it a blown YSUS should be fixable. i even found a german repair forum with a workaround (diy YSUS driver chip) for blown ysus boards on LG (and other) units, don't know if philips is similar there.
                  let's see what the seller says, but i might have a new toy next week. or two.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    This might be of interest
                    http://www.scribd.com/doc/7580885/LG...raining-Manual
                    Looks like Plasmas have a lot more junk in them than LCD's.
                    Either that or it's that the biggest I've look at so far is 27".
                    All seems to be related to the actual screen though.
                    Tuners and Video boards could easily be the same.
                    - Dr Seuss
                    • Wizard
                      • Mar 2008
                      • 2296
                      YSUS is what it say. There is a design flaw in the STK IC (cannot obtain this) that breaks solder (it is a overlap on the edge sitting on pads, dumb to do and it will crack for SURE is what blow the MOSFETS arrays in that same STK IC, this also sometimes takes out the YSUS drivers boards. And there is fixes in the logic board so it was came out as a kit for the Philips-LG using V7 panels.
                      Many of them eventually dropped STK and went distcrate drivers instead. Far more reliable. Samsung included.
                      YSUS big board is for horizontal lines individually addressable with 2 narrow boards on left side while other ZSUS board is common tied to all other horizontal lines so each cells have 2 lines in parallel. That are the neon electrodes.
                      While the boards at bottom of the panel are address lines running vertically up and down. YSUS and ZSUS set up the cell charge just to the point it sparks off into excition if kicked off by the address line. This pre-firing charge is what cause cells to glow. Hence you can't get high enough constrast with this panel and another reason for the smoked glass placed in front of panel itself also to protect it and to protect customers from the high voltages and heat.
                      With all the high voltages and large area of capacitanace coupling to everything, plus neon current making some heat, that is reason take tremdeous power to run. The 42" panel I see has wattage printed on the back on the panel itself along with few voltages is around 300W for whole white, at full brightness typically. Hence the back of the plasma panel is metal (panel glass is bonded to this, early ones were diecast potmetal then stamped steel, with mounting fixtures riveted to this), and lot of driver ICs and transistors heavily heatsinked.
                      Newer plasma panels now have driver ICs on the TCP so the circuit strips is simply bus circuit. If the IC dies, panel is junk and must go back to panel repair factility.
                      This link is about LCD but newer plasmas utilizes TCP of their IC dies pressed between metal plates and thermal pads for heatsinking.
                      http://www.fps-europe.com/repair.html
                      These are more likely to fail compared to LCDs due to termendous power and high voltages involved.
                      Cheers, Wizard
                      • Wizard
                        • Mar 2008
                        • 2296
                        deleted
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          Great more STK ICs I've had enough of those on both my RPTVs. After some Arctic Silver 5 though and subbing them for the newer revised ICs they've been rock solid.
                          From my knowledge Sanyo discontinued them in 06 or 07. Sanyo said it was because of the fall of RPTVs and also probably because as you said plasma manufacturers moved to discrete components.
                          So basically the YSUS is the display driver?
                          Very nice link PC I'm reading all of this.
                          • Wizard
                            • Mar 2008
                            • 2296
                            The logic board (connected by LVDS cable from mainboard) do all the directing and timings to the power transistors and drivers ICs to fire them off at correct timings/sequences.
                            Logic board is much like a music director telling players to play their instruments at correct sequences (power transistors and drivers ICs).
                            There are 2 big boards, YSUS and ZSUS using power transistors or a BIG STK ICs that is where real power is. Merely brute power, the sub circuits (board strips along the two edges of panel do the final channeling to correct lines (scanning).
                            YSUS board on left side is channeled to the invdividual lines as directed by the logic board while ZSUS board on right side is tied to all the lines like a tree. Both YSUS and ZSUS has to cycle the different voltages line by line rapidly. It has "discharge voltage to snuff out the cells, charge up the cell to the level where small trigger set neon off into ionization; light up the cell and surstain voltage to have cell lit without excessive current. Etc. Very, extremely complicated signal. Not simple blink on and off.
                            And LOUD in radio radiation, this is major reason the plasma units have metal back. I see this static on CRT TVs when we test run and adjust plasma units with their back removed.
                            Cheers, Wizard
                            • i4004
                              • Oct 2006
                              • 2029
                              line by line?
                              like crt scan?
                              doing all lines at once would be too much voltage?
                              complex, yeah, but i bet not as complex as ntsc vertical blanking...hehe...
                              • i4004
                                • Oct 2006
                                • 2029
                                some other goodies from there
                                http://www.scribd.com/tag/training%20manual
                                sanyo lcd manual seems interesting
                                other categories
                                http://www.scribd.com/browse/Manuals/
                                • Wizard
                                  • Mar 2008
                                  • 2296
                                  Pixel addressing one by one, hence high KHz, even near MHz.
                                  CRT scanning STUPID simple, that was easily done with tubes back then.
                                  But plasma panel is most complicated to do especially trying to dim a neon action that is nearly impossible to dim to begin with, hence the complications.
                                  Cheers, Wizard
                                  • kikkoman
                                    • Jul 2007
                                    • 691
                                    i found out the model number. they're 42PD1609 's - professional units (no tv tuner, just monitors) and most likely come from an airport. this probably means they're somewhat burnt in.
                                    guess i'll back out.
                                    thanks for your replies though.
                                    • Wizard
                                      • Mar 2008
                                      • 2296
                                      Good idea!
                                      Cheers, Wizard
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        May also mean they were installed outdoors in a box on a pole.
                                        - Dr Seuss
                                        • celiabrown
                                          Issue with Plasma Philips 37inch chassis FTL2.1
                                          by celiabrown
                                          Hello guys,
                                          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                          Can someone has any symptom like this ?
                                          Thanks​
                                          05-09-2024, 10:56 PM
                                        • kotel studios
                                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                          by kotel studios
                                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                          State I got it in:
                                          Squealing from the PSU
                                          After logo I get a blank screen
                                          After 10 seconds of having a blank display w/ backlight the TV dies
                                          Give it 7-10ish seconds again and it starts to bootloop.
                                          What I did so far:
                                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                          Checked all voltage rails:
                                          5VSB - 4.8V
                                          AMP+13V - 14.4V
                                          13V - 12.98V (in manual 12V)...
                                          09-21-2025, 02:00 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • double_DD
                                          Philips curling iron - is this a common AC cable?
                                          by double_DD
                                          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                          08-18-2025, 10:04 AM
