Philips 52PFL5605H no power fixed by replacing R106
  • piernov
    • Jan 2016
    • 4439
    • France
    Philips 52PFL5605H LED TV with FSP190-3MS01 power supply board.
    No power at all, 3.3V standby missing.
    0V on the secondary, 325V on the primary cap.
    So we start by looking at the 3.3V controller IC, part number STR-A6069H.
    325V on the D/ST pin, but the IC is not switching. VCC pin voltage is oscillating between 9V and 13V. BR pin is oscillating between 1.8V and 2V.
    Looking at the datasheet, we can see that the brown-out threshold on BR pin is 4.8V, and we have a voltage much lower than that. Checking the typical application circuit, we can see that this voltage comes from a resistor voltage divider. Either one of the resistor is bad, or the IC is bad.
    Following the traces on the backside of the motherboard, we encounter a set of resistors and start measuring them. It turns out that one of them, R106, has gone bad. Its color code indicates a 2.2 megaohms resistor, but it is measuring around 50 megaohms. After replacing it with 2*1 megaohms, the 3.3V standby is back and the TV is fully working again. BR pin is now a little above 6V.
    Took me 2 hours to figure that out because I never suspected this resistor, a small axial resistor which looked perfectly fine.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Philips 52PFL5605H no power fixed by replacing R106
    Nice fix!
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • double_DD
      Philips curling iron - is this a common AC cable?
      by double_DD
      Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
      As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
      Not sure if this is something Philips proprietary, or a standard, but the cable plug...
      08-18-2025, 10:04 AM
    • janos6662000
      Philips 47PFS7509/12 LCD TV problem
      by janos6662000
      Hi
      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
      When i applied cable signal to check image, i had normal picture, but TV was restarting.
      I downloaded original firmware and applied the update, but the problem remained.
      From a colleague i received a "factory package software" which is a lot bigger.
      I made another firmware update, but still did not solve the problem.
      Somewhere on the way the error got worse, because at the moment the...
      08-12-2025, 12:54 PM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
