Vizio E601i-A3 Won't Power On
  • impala454
    • Jul 2011
    • 30
    I'm trying to fix a Vizio E601i-A3. User says after a lightning storm the TV quit powering on. I looked at the power board and there's a slight burn mark near the power connector near the fuse. I'm not super familiar with these types of fuses so I'm not sure how to tell if the fuse is blown (it has continuity on my DMM). The electrolytics all look ok. I get no voltage on any pin of the mainboard output connector. Here's some photos:
    Power board overall shot
    Power connector and fuse
    This is the burn mark on the other side of the power connector
    Main caps
    Secondary caps
    Any thoughts?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E601i-A3 Won't Power On
    What dv voltage do you get across the terminals of 450v capacitor. Picture 4
    • impala454
      • Jul 2011
      • 30
      About 210V
      • impala454
        • Jul 2011
        • 30
        (on both)
        • dskall
          • Oct 2016
          • 2905
          • usa
          What is your line voltage? You should list your voltage or country
          • impala454
            • Jul 2011
            • 30
            120v (us)
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              What are the voltages on CN201 when you plug in just the PSU, nothing else connected to it?
                So the meter is good and set properly to read VDC between the two legs of the main filter cap?
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  the 210V DC on the main filter cap don't make any sense unless you have 150V AC input and I really doubt that one.
                  • impala454
                    • Jul 2011
                    • 30
                    Arg, I think my meter is messed up. Reading 14V on a fresh 9V battery and 1.9V on a 1.2V. I definitely was not getting anything out of the power connector though.
                      Get good working meter first before going any further, bad data makes it hard to troubleshoot the problems.
                      • impala454
                        • Jul 2011
                        • 30
                        Will do
                        • impala454
                          • Jul 2011
                          • 30
                          Ok, meter just had a dead battery and is working now. Both caps read about 160V.
                          • impala454
                            • Jul 2011
                            • 30
                            I'm trying to figure out where to measure it.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8352
                              Unplug cn201 so that the pins are exposed. Find the gnd pins and put the black probe on there. Plug in the PSU and probe the other pins with the meter set to dc volt. I am looking for STBY voltage. That gives us a starting point.
                              • impala454
                                • Jul 2011
                                • 30
                                Ok gotcha, here's the connector:
                                Using pin 5 as ground, the only pins that showed non-zero voltage was pin 8 and 9, which showed 0.03V.
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8352
                                  So there is no 3.3V DC on pin 1? That means we have to work on getting that going if there isn't any. If there is no voltage on pin 1, unplug the PSU from mains, put your DMM into diode mode and check between pin 1 and one of the GND pins for a short. What is printed on U501 on the back side of the board? If you follow pin 1 backwards, it goes to that U501 IC.
                                  • impala454
                                    • Jul 2011
                                    • 30
                                    Checked between pin 1 and 5 and got 0.390. 0.557 in the other direction.
                                    Here is the back side of the board at U501
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8352
                                      I can't see any markings on that U501. For me that IC is just black on that picture. Can you identify any printings on that IC?
                                      Maybe you can put the black lead of your meter (set to DC V) to one of the GND pins and with the red lead from your meter probe all legs of U501, while the PSU is plugged in. Be careful though. Don't touch anything on the primary side of the PSU.
                                      I see a new PSU cost something like $35 at SJ.
                                      • impala454
                                        • Jul 2011
                                        • 30
                                        So I read as best I could and looks like 3 lines of alpha:
                                        549887
                                        61833
                                        36D5D
                                        The legs all probed 0.1V or 0.
                                        I keep wondering if that burn mark near the mains input has something to do with it.
                                        Something interesting, I posted this other thread for a smaller 32" TV. These were both in the same apartment during the storm and both have the same issue (seemingly no power). I didn't find any burn marks on the other one but the main caps both seem to charge up.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • bscottjohnston
                                          Vizio M55-E0 won't power on - fuse intact
                                          by bscottjohnston
                                          Vizio PSLL241206M inside an M55-E0.
                                          Here's an odd one. Why in the world do I have 76 VAC on the fuse when I have measured 115 VAC on the input power cord? Does this point to something known or simply another SMPS problem I need to run down?...
                                          02-20-2024, 12:18 PM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
