TV won't turn on high pitched noise from power supply board
  • FerretFiend
    • Sep 2017
    • 6
    • US
    I purchased this TV less than 3 months ago brand new from Target and it's already broke. Target won't take it back and the manufacturer won't repair it because I don't have the receipt and Target can't get me a new one.
    So I'm here looking for help troubleshooting my problem. I was watching a quick show while eating and a high pitched sound started, the display flashed multi-colored vertical and horizontal lines and then when black.
    I unplugged it and the sound stopped, plugged it back in and it started again, TV hasn't turned on since though the LED “off” light stays on (it blinks when it turns on).
    It is a:
    TCL 55US5800
    S/N 1609GTC000803A02482
    I've done a little research and it seems like it could be the capacitors. I listened through a paper towel tube and the loudest ones are the 2 big ones I bent up and the single one at the bottom but for consistency I would like to replace every big capacitor on that board.
    I had only the power supply board plugged in with the 2 connections going to the other boards unplugged at one point and it changed the sound, it was much quieter.
    I need help making sure replacing the capacitors will likely fix my problem or if something else got shorted out or something else is causing this load problem on the caps.
    The other thing I need help with is finding the right capacitors to buy so that I can replace them. I'm a biomed (medical equipment technician) by trade and have a little electrical component experience and board troubleshooting and soldering. I have access to a DMM and possibly a cap tester, an oscilloscope and DC power supply if needed.
    Capacitor values I've seen:
    56uF 450V
    680uF 25V
    22uF 60V
    220uF 50V
    Images to come after I get a hosting site, photo bucket you apparently have to pay for now!
  • FerretFiend
    • Sep 2017
    • 6
    • US
    Re: TV won't turn on high pitched noise from power supply board
      Made in Sept 2016, that is a year ago, and you bought it 3 months ago?
      So what kind of Voltage testing have you done so far?
      What are the Voltage on those pins of the connector of the power supply board that goes to the main board? Those pins have label so make sure to report the each pin name and follow by the DC Voltage reading for each pin.
      • FerretFiend
        • Sep 2017
        • 6
        • US
        Yes made a year ago and purchased on June 12th of this year. I don't have my DMM with me it's sitting at work so I haven't done any testing. I don't see any voltage labels except for the low voltage chart thing and I don't see labels on the board that match. The longer connector going inside the TV to the LED's are labeled mostly LED + and LED - where as the shorter connector going to the main board is labeled just pins 1 - 14. Is this what you were asking, measure the voltages on each pin?
        • dskall
          • Oct 2016
          • 2905
          • usa
          Can't zoom on your pictures. Would work better if you post under go advanced. Manage attachments
          • FerretFiend
            • Sep 2017
            • 6
            • US
            I tested 3 of the caps making the most noise and they tested fine, what do you guys think is the problem? I'll get voltage readings sometime this weekend if I'm not busy. Thanks for your guys help!
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              highly unlikely to be a cap problem.
              until you list voltages from the ps to the main board, we can't progress any further.
              the harness in question has 2 layers of cables and we need all voltages in stby and when you have attempted to power on.
              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
              • dskall
                • Oct 2016
                • 2905
                • usa
                Is it making noise in standby or when you try to power it on?
                • FerretFiend
                  • Sep 2017
                  • 6
                  • US
                  Ive done a little more troubleshooting this morning. It does make this noise is standby and the noise doesn't change when I attempt to turn it on. The noise changes when the main board is unplugged, it changes to a kind of clicking sound with a pattern to it.
                  When I measure the voltages on the pins what do I use for ground/return/black lead? Do I use the posts in the corners?
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    anywhere on the back cover of the panel is fine for cold ground reference.
                      The metal frame of the TV is fine, e.g. the wall mount bracket holes, or screw holes into metal.
                      • apd_jack
                        • Apr 2018
                        • 8
                        • United Kingdom
                        I wonder that is there any solution found for this issue? Cause i'm having very similar one too
                        My replaced mainboard is causing noise from PS, or at least i think it is...
                        Cheers
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          The sound probably manifests itself because of a shortage voltage on the main board loading the power supply down. You say you replace your maid board? So does the tv work now?
                          • apd_jack
                            • Apr 2018
                            • 8
                            • United Kingdom
                            @freakaftr8 Yes, tv works fine.
                            It is kind of silly actually;
                            I replaced my LG 47 inch LX6900's mainboard with a mainboard from same model's 55 inch (don't ask why )
                            It works perfectly fine except that noise.
                            And yes, most probably it causes voltage shortage to PS cause it thinks it feeding a 55" screen.
                            But i don't know what can i do to fix it since it's not about capacitor malfunction.
                            I mean, is there any way to decrease mainboard's power consumption, or should i increase Power supply's voltage circulation somehow?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              I'm not sure if that's is needed. Sometimes coils just make noise for no apparent reason. Also if the output voltage of the power supply on individual pins match up with the input voltage requirements of the main board then there's no reason to switch up the voltages At last there's a certain section of the made board requiring more or less voltage.
                              But in this case eventually something when manifest up to an improper displaying screen or firmware problems or audio problems Which you do not seem to have
                              • apd_jack
                                • Apr 2018
                                • 8
                                • United Kingdom
                                No, there is no problem with screen, operating system or auido. Only this annoying signal kind of noise.
                                Actually, i don't know if there's any section of the mainboard requiring more or less voltage. New board is slightly different then previous one. It has some extra pins, yet it's fine without plug them.
                                I should check it with voltameter, right? in order to figure out which parts hightened up its voltage requirements..
                                I wonder, even if i spot them, will there be any way to disable them without breaking the board ?
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  If you could take a snapshot of the power supply connector and then the main board connector and look and see if there's any kind of legend on there that shows the pin outs we might be able to see if there's any differences
                                  • apd_jack
                                    • Apr 2018
                                    • 8
                                    • United Kingdom
                                    Here are some pictures of the chassis and board layout.
                                    Weird thing is, the sound not coming from Ps but this little board at left edge corner of the chassis, it stands at the back of the remote sensor and intelligent sensor. You can also see it in the pictures.
                                    Do they make sense?
                                    @freakaftr8 Thank you very much by the way man. I appreciate your interest.
                                      https://www.badcaps.net/forum/attach...1&d=1523494009
                                      This board?
                                      • apd_jack
                                        • Apr 2018
                                        • 8
                                        • United Kingdom
                                        Originally posted by budm
                                        Yes.
                                        Its cables coming from Ps though, when they are unplugged sounds stops but this time Tv can't be turned on..
                                        What is it then?
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • Rayblaster
                                          HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                                          by Rayblaster
                                          Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                                          I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                                          12-30-2024, 06:28 PM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
