No-name PSU repair (ChangHong TV)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. You know how we've got a thread about the worst/strangest power supplies ? Well this TV inspired me to propose we make one for the worst TVs as well I've just fixed a ChangHong TV (yeah, this exists ) which had power supply issues and while the PSU is definitely not as bad as some others I've seen in terms of design, it's still a strange specimen, so I decided to share my findings with you.
    Now the repair itself is nothing to write home about: the PSU went "click-click-click" and it was just a busted cap (C5 in the picture) on the VCC supply for the switching IC, which is a little SMD IC on the bottom (didn't picture that sadly). Just out of curiosity, I looked up the model number of the PSU and much to my surprise not even Google's heard of this thing before...seriously, searching for AYL220405 didn't return a single result, not even an auction site where someone may be selling one of these - NOTHING So I'm....proud ?....for lack of a better word, that if someone runs a search on google for this thing now, they'll probably run into this post I must admit I'm disappointed I didn't get a chance to grab some pics of the bottom just in case someone will ever need a value of a SMD resistor that's gone boom....sorry, my bad
    So if something were to go horribly wrong on this PSU and you had some fried resistors and SMD capacitors that you had no way of knowing the values of, you're kinda screwed unless you're a real pro and know the circuit topology and know exactly what values the components should have based only on how they're connected. Fortunately it wasn't the case here - just a simple dry cap, although I DID fix one of these "Changs" before which was a lot worse: fried traces, blown SMD resistors and caps....it was a mess. After a lot of scrubbing, tinkering and rebuilding traces I was able to get that one to fire up also. Make sure you're using the series light bulb when doing this ! I had mine at full brightness a couple of times when messing around, so something would've blown for sure.
    So there you have it, a completely useless piece of information that nobody asked for but I thought I'd share anyway Cheers.
    Wattevah...
    • 31291
    Re: No-name PSU repair (ChangHong TV)
    looks very good actually,
    even has an isloation slot under the opto.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      It does, yeah. It's heaps better than other PSUs....don't know much about it sadly
      Wattevah...
        I've seen similar PSUs by Megmeet. Not the worst in the world, though some engineer at Megmeet thought it was okay to replace 330nF poly-film caps with 10uF electrolytics in the primary transformer drive circuit. The result is popped electrolytics and backlights going out after a few years cause those tiny 'lytics just can't take the pulses from the SMPS well.
        • CapLeaker
          Leaking Member
          • 8352
          I've seen a very similar power supply too like that one, but can't remember what brand it was, besides something no name Chinese made PSU.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            It may have been a Megmeet like Tom said. I was expecting this one to be a Megmeet as well, since it looks very similar and that other ChangHong I first fixed (the one that was really fried) had a Megmeet in it.
            Wattevah...
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              i found a few hits through duckduckgo, mainly for a 22" unit.
              changhong is related to celestial. we get a few of their things over this way.
              WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                • 31291
                it cant be Megmeet, they didnt use U shape heatsinks to create an oven for the caps!
                same colour pcb though.
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  I think i see a U shape [or C shape] heatsink around the output capacitors.
                  I'm not a expert, I'm just doing my best.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    There is one....very typical setup to speed up failure in MANY PSUs....unacceptable :|
                    Wattevah...
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      They bake the output capacitors so they can fail and the owner of the TV will buy a brand new TV so the output caps on the new TV's power supply get baked and so on. :P
                      Or the owner gets the power supply replaced/repaired.
                      • CapLeaker
                        Leaking Member
                        • 8352
                        It wasn't a Megmeet, it was something else...
                        • tamerelapute
                          [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                          by tamerelapute
                          I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                          Except the cpu, I cant feel anything getting warmer.
                          I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                          I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                          I believe that if the cpu was fried,...
                          07-08-2024, 03:28 PM
                        • jeremy96
                          PS4 Power Button Traces
                          by jeremy96
                          I recently bought a used PS4 and discovered that the power button is broken. Upon closer inspection, I found that the traces for the power button on the PCB are damaged and torn.
                          Does anyone know where these traces lead or have any advice on how to repair them?
                          Thanks in advance for your help!​...
                          05-26-2024, 05:01 AM
                        • x_orange90_x
                          Samsung UN65AU8000FF fried by water
                          by x_orange90_x
                          I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                          10-16-2025, 08:40 PM
                        • ktmmotocross
                          can i see actual traces in BV or how to see it?
                          by ktmmotocross
                          guys can i see actual traces in BV or how to see it?
                          09-10-2025, 01:41 AM
                        • Lapsmith
                          Fried capacitor on Dell-5520. Guilty as charged.
                          by Lapsmith
                          While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                          07-06-2025, 11:08 PM
