PS4 Power Button Traces
  • jeremy96
    • May 2024
    • germany
    I recently bought a used PS4 and discovered that the power button is broken. Upon closer inspection, I found that the traces for the power button on the PCB are damaged and torn.
    Does anyone know where these traces lead or have any advice on how to repair them?
    Thanks in advance for your help!​
  • jetuaime81
    • Jan 2017
    • 16
    • india
    One contact leg of the button should be that via marked in yellow and the other contact to ground plate. I believe that via is still ok from the photo. You can check the voltage on it to confirm.
    • themosttogain
      HP Envy 13-BA1565na with intermittent power button
      by themosttogain
      Hope someone can give me some suggestions on this because i'm at my wits end with it...
      I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
      Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
      07-12-2024, 03:03 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • TimeRabbit07
      Asus FX517ZC charges but power button does nothing
      by TimeRabbit07
      Hi all!
      I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
      Here are its various numbers and identifiers:
      Model short: FX517Z
      Model long: FX517ZC-HN114W
      SN: NANRCX01S57842E
      CN: 3SDB 12M
      MFD: 2022-10
      Motherboard model: DA0NJLMBAE0 REV E
      Symptoms:
      The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
      History so far:
      The...
      09-04-2024, 05:48 PM
    • reessi
      Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
      by reessi
      With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
      No corrosion any where!
      Tried a replacement power button off ebay and the same.
      Very occasionally it will work with the power button connected!
      Same results with or without the battery.
      Can it be a fault with the Audio board or the mainboard?
      The touch Id assembly connects through the Audio board first then to the Mainboard.
      Flex...
      06-26-2024, 03:31 PM
    • hoarderteks_kyriakos
      Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
      by hoarderteks_kyriakos
      Hello.
      Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
      Here is what happened:
      At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
      10-08-2025, 07:33 AM
