Samsung vertical lines
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4480
    • Italy - Milan
    Re: Samsung vertical lines
    Since my English is not the top, the screen has one internal bezel that hides two "band" circuit boards, attached to tcon board with usually 2 or 4 ribbon cables, now those band boards are attached to the screen with multiple "tab bonds" , flat cables glued to the board and the screen (glass), on each tab bond there is a wide thin chip made of glass, is on this tab bon the burn mark? If yes you can contact the company if you find them...
    • badbruin44
      • Aug 2017
      • 20
      Yes that sounds like it. I will check into it thanks again. It is a long way from where I live in Canada I think I will have to give up and take my losses just another life lesson as mentioned earlier buyer beware sucks but oh well.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Check this video to see your problem.
        The material is not that expensive , around $75.
        The problem is , you need the machines to repair it.
        Sell the boards or list the tv as defective.....
        https://www.youtube.com/watch?v=4M3ohP9h474
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          maybe worth a read
          https://www.badcaps.net/forum/showth...ight=tab+bonds
          Edit!! just re read the whole thread a tab bond fix wont work if the chip on flex etc is damaged/faulty
          • badbruin44
            • Aug 2017
            • 20
            K thanks guys yes that is the culprit and it has a burn mark on it where it shorted I don`t think I have the means or equipment to repair and yes it was hot to hot to touch.
              If it's got a burn mark he isn't gonna be able to shim it or do anything like that. He needs a new source driver, no idea where you'd get one.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4480
                • Italy - Milan
                #27
                Where to get a source driver is not the main problem, some can be found on Aliexpress, but who can change it.
                • badbruin44
                  • Aug 2017
                  • 20
                  Ya still a big problem either way. This is a great site to find and trouble shoot equipment thanks all. I will experiment with this and probably part out
                  • Stanley1843
                    Screen Display Vertical Multicolor Lines
                    by Stanley1843
                    Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                    06-29-2024, 11:54 AM
                  • Maverick1234
                    Colored Vertical lines on Samsung UN55C6400RF TV
                    by Maverick1234
                    I have a Samsung 55inch TV (UN55C6400RF). It has started showing colored vertical lines. I have opened the TV and the power board had one pin (out1-) which is discolored (Model # bn44-00358b). Can this be bad or is it the T-Con board (Model # D03464E0J09B6012066). Any recommendations on diagnosing the issue?
                    Thanks,
                    Sanjay
                    09-13-2021, 02:43 PM
                  • Ihandyrepair
                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                    by Ihandyrepair
                    Hi guys
                    I just started fixing 4k TV few months ago. so I am still learning a lot
                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                    then it started to show the ghosting white image.
                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                    it has 3 thin small boards at the bottom of the...
                    12-05-2022, 04:18 PM
                  • x_orange90_x
                    Samsung UN46C8000XFXZA vertical bars/horizontal lines
                    by x_orange90_x
                    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                    09-04-2023, 12:09 PM
                  • mrsith
                    Samsung UE58TU7100K - no picture, vertical line
                    by mrsith
                    Hi.
                    Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                    This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                    Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                    02-07-2023, 11:18 AM
