Repair Power Board KB109WJQZ for Sharp TV LC-60C6500
  • Louis82
    • Feb 2012
    • 240
    Hello there,
    Can someone help to troubleshoot this power board KB109WJQZ for Sharp TV LC-60C6500.
    No STB voltage, DC filter caps shows 165V. I found a defective diode location D7950 part number SB2100. I replaced it with another Diode STPS2150 from another Sharp board and I still not getting any STB voltage. Suggestions on what to check next ?
    Thanks in advance
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Repair Power Board KB109WJQZ for Sharp TV LC-60C6500
    Check capacitors C7950A and C7950B
    What is the part number for Q7120
    • R_J
      • 9555
      Check R7900 to see if it is open, it should be 2.2 ohms, if it is open ic7903 is bad
      • Louis82
        • Feb 2012
        • 240
        Thanks guys. I did notice R7900. I been looking for IC7903. I will report back soon if I have it.
        • Louis82
          • Feb 2012
          • 240
          Ok. There is definitely an improvement. 5V present on Pin 15 which is BU5V but still nothing on Pin 24 STB. Any thoughts?
            Pin 24 'STB. is the BL-ON pin which it receives the BL-ON signal from the main board.
            You need to report DCV (when TV is OFF and when power switch is activated) for all the pins of the PD connector so we can see what are missing.
            You must put down pin number and follow by pin names so we do not have to guess what they are.
            • Louis82
              • Feb 2012
              • 240
              Thanks guys. Installed circuit board on Tv and is working properly. Thank you for your time.
                Can you please post the DCV reading on PD pins so we will have the reference to as what they should be for working board (board connected to the main board)? It will help lots of people in the future.
                • seosan
                  Ronaldo 035
                  • Apr 2018
                  • 27
                  • japan
                  Hello Louis. Did you get any voltage on pin 24 (STB) ?​
                  • seosan
                    Ronaldo 035
                    • Apr 2018
                    • 27
                    • japan
                    I'm back to tell you how I solved my problem with a Sharp LC-50U45 (Japan).
                    First, I identified the damaged LED bar and removed the respective wire from the connector, leaving all the others connected.
                    Then I interrupted the [ERROR] signal from the connector between the power supply and the main board. I connected this wire to the device's body (GND).
                    And finally, I entered service mode with the [input] and [- volume] buttons, turning on the power... and voilá.​
