Panasonic Plasma - different YSUS board rev
  • meciu
    • Nov 2016
    • 37
    Hello three.
    I have a broken plasma TX-P42G15E with 5 LED blinks and I've purchased used and working YSUS board but it is a bit different than mine..
    I've got broken TNPA4844AH and purchased TNPA4844AD from TX-P42G10E
    And my question is.. swapping board will work? Or I need to solder additional components from my broken board?
    Thanks!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic Plasma - different YSUS board rev
    It will probably work! Do you see any different components on the board?.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Also , there is a great chance that the panel is exactly the same.
      • meciu
        • Nov 2016
        • 37
        @Moreno83
        So at this moment I see a few differences with caps and this blue things..
        picture in attachment
          You may have an issue if the other board is from a 46" or 50" panel. This could cause maldischarge (colour distortion, stuck pixels, image retention) or other faults, and may lead to the new board failing.
          • Lloyd6202
            • May 2017
            • 59
            Take those two components out and be done with it...u shouldnt have a problem then
            • tw2005
              • Oct 2011
              • 6458
              I just did this myself but in the reverse. Used G15 SC for a G10. The panel part numbers were the same. I don't know if you can access Shopjimmy but a reverse search on APnel MC106F16T12 shows both those revisions fitted.
              Based on that, I would simply fit and forget. I did.
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
              • canadaboy25
                Panasonic TC-P54VT25 No image. A or D board?
                by canadaboy25
                I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                01-17-2021, 01:06 AM
