backlight issue Samsung UE32EH5000
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi Guys i have the Samsung LED model UE32EH5000 when it is switched on i get no backlight. i have tested the LED strips and all check out. the voltages i get from the power supply to backlights is.
    182v
    182v
    0v
    278v
    278v
    and the voltages i get from PSU to AV board is.
    13.10v
    13.10v
    13.10v
    13.10v
    0v
    5.27v
    5.27v
    0.90v
    13.10v
    4.88v
    0v
    0v
    5.29v
    3.54v
    does anyone know what the issue is or what i can do to further troubleshoot. thanks.
  • Doc38343
    • Apr 2015
    • 402
    Re: backlight issue Samsung UE32EH5000
    Do the backlights do anything when you turn it on like blink?
    Have you tried it with the power jack going to the main board disconnected?
    How did you test the LED strips?
    Had a similar issue recently but not exactly the same. Mine had one LED working intermittently and I found it had a bad solder joint on the led. I killed it trying to fix.. but put a new bulb on later.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      hi there thanks for quick reply. backlights do nothing at all when tv turns on. tried it with cable to main disconnected and got no blinks from backlights at all. i tested the led strips using a LED tv backlight tester and all when on no proeblem as i stripped screen out to check.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Do you have a single led string. If so I would check the mosfet on the return side of the led string.
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          there is 4 or 5 led strips inside tv.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I believe they are all connected in series since Pin1 & 2 are TOP1+, Pin 3 no connection Pin 4 & 5 TOP1-
            Also 140V for 3V leds would be approx 47 leds in series.
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              what can i do to further test ? could the PSU be at fault if all LEDs seem to be ok ?
                The LED power supply Voltage chart shows 140V as printed on that power supply board.
                What Voltage does it show on your LED tester?
                Since you are getting 278V then it has open circuit some where.
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  im guessing that would be fault with the power supply ? and will test with LeD tester just now and report back.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    No, its indicating a possible led problem (shorted led(s)) or an interconnection problem between the led strips.
                    Edit
                    Shorted leds would not stop the led tester working but a shorted led would trigger the protection shutdown of the led controller IC.
                      As dick_barton has indicated, it can also be that the MOSFET on the return side may be bad on not being turned on.
                      Right now the power supply is not seeing the load so its output went up high.
                        OK, I just look at the bottom side of the board at shopjimmy, the LED return is done through the MOSFET inside the LED driver controller IC 9101S.
                        Get the P/N of that IC so we can look up the spec. sheet.
                        Pictures provided by shopjimmy.
                        BTW, no one work on this TV before, right?
                        Shop jimmy only shows 2 LED strips.
                        http://www.shopjimmy.com/samsung-cy-...s-2-strips.htm
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          tested led strip with tester as a whole and per strip. i am getting 113v for whole string and 28.1v per strip. @Budm the IC P/N is PC1AC SLC101 0
                          as far as im aware tv has never been opened or tampered with.
                          • R_J
                            • 9535
                            It looks like in post #1 you measured the led voltage with reference to chassis, You should measure across cn802, positive probe to pin 1 and negative to pin 5
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              @R_J yes i measured with MM from ground on chassis and red probe on pins. will do that just now and reply.
                              • Mikeyboy2007
                                • Mar 2013
                                • 745
                                • Scotland
                                with probes on 1 and 5 i get 0v with multi meter set to 200 and 250
                                • R_J
                                  • 9535
                                  What voltage do you get across C9111, you may need to check that when you first turn the tv on.
                                  • Mikeyboy2007
                                    • Mar 2013
                                    • 745
                                    • Scotland
                                    ok i flipped up PSU to read voltages on C9111. when i plugged in it went to 14, 17 then 19 then 1 displayed. i unplugged tv and voltage appeared 180 or so tjen gradually dropped. took 2 minutes for it to go back to 0v after switching off from plug.
                                      That means the GND return for the LED is open which will be the internal MOSFET inside the LED controller IC. I did not look up the spec sheet for that IC yet.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        The voltage listing for CNM803 (post #1) does not look correct. Could you list the Pin number, legend, voltage read
                                        Pin1, B13V , 12,8V
                                        Pin2
                                        Pin3
                                        Etc
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • Manucsl
                                          QE65Q800TATXXC Samsung TV Issue
                                          by Manucsl
                                          Hello.
                                          My TV is a QE65Q800TATXXC Samsung TV.
                                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                          Any ideas to check would be very appreciated 😊
                                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                          02-19-2025, 07:47 AM
                                        • FourRunner
                                          Display issue Samsung TV UA65JS9000W
                                          by FourRunner
                                          I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                                          10-03-2024, 07:05 PM
