LG 60PC1D-UE picture messed up
    Re: LG 60PC1D-UE picture messed up
    You wouldn't have any pic if your buffers were shorted.
    • shelby5041
      • Feb 2009
      • 1505
      • united states of america usa
      #102
      i know...but per serv manual test method they are both shorted
      i put 1 lead on large floating ground pad and raked pins where rubbon cables connect to.....
      is this correct method to test for short?
      • shelby5041
        • Feb 2009
        • 1505
        #103
        i posted a pic of serv manual page couple messages back..can u verify my buffer testing method is correct?
        • shelby5041
          • Feb 2009
          • 1505
          #104
          and i havent tested tv for pucture recently....just been trying to isolate no vsc vsetup issue
          it does appear buffers are shorted unless my method of testing is incorrect
            Listen to me: Your buffers are not shorted if you have any picture.
            You would not have a picture (that is, distinguishable lines, that show parts of an image) if your buffers were shorted.
            If your buffers were shorted, your Vsc would be zero, not crazy.
            • shelby5041
              • Feb 2009
              • 1505
              #106
              ok testing method per serv manual is wrong
              they prob made a typo
              thanks
              • shelby5041
                • Feb 2009
                • 1505
                #107
                on my cheap multimeter vsc registers out of range on 1000v setting
                does not fluctuate
                sorry for all questions....just want to fix my tv
                  It's probably just the interference from the TV driving your meter crazy, you might need a better meter.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Main board = a/v input board.
                    Run the test patterns !
                      Don't think you can on this one...
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #111
                        dont know how to run a test pattern.....and i used my neighbors fluke meter and get same results for vsc vsetup
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #112
                          tom....i believe serv manual wrong on testing buffers
                          i tested all 4buffers i have and same pins on all 4 had continuity......which i thought was odd....so i did more testing and it appears on each connector therr are 4ground pins ....so you cant rake all pins ..if u look on bottom of board trace compared to top of board you can see which pins are ground....so it appears buffers are not shorted as you stated.
                          sorry....
                          • shelby5041
                            • Feb 2009
                            • 1505
                            #113
                            im going to buy another logic board and see how tv acts
                            you 100% do not think its a z or p/s issue?
                            and what about main a/v board like martli said could be?
                              I already said I didn't know what the fault was without using a scope on the TV to tell what is wrong with the drive waveforms. It's not the typical kind of fault you get with a Z-sustain failure.
                              • shelby5041
                                • Feb 2009
                                • 1505
                                #115
                                ok thanks if another logic board doesnt fix it ill throw tv in trash
                                i appreciate ur help...it appears this tv may be non fixable for me
                                  I'd put it up for FREE on Craiglist/etc or even ebay so it doesn't get completely trashed, if you can't fix it.
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    #117
                                    maybe.....
                                    but sure does look like not fixable..we will see...maybe i will keep until someone has same issue and can tell me specifically what needs to be replaced
                                    thanks
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      #118
                                      thats how i fixed my samsung 60 inch..it had a very common issue and i fixed it
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #119
                                        hi just got 3rd control logic board
                                        no change
                                        same exact symptoms....i would say this confirms that it is not a control logic issue
                                        if someone has any advice what could be causing the issue i would appreciate it
                                        i have replaced buffers.....no change at all ..same no vsc no vsetup voltages
                                        i have replaced y board..no change at all...same no vsc.. no vsetup voltages
                                        i have replaced control board 2 times.no change at all..same no vsc and no vsetup voltages
                                        only way i get good vsc and good vsetup is if power to control board is disconnected
                                        and removing power to control board and getting good vsc and vsetup voltages happens with all the boards i replaced...in any order...doesnt matter
                                        • shelby5041
                                          • Feb 2009
                                          • 1505
                                          #120
                                          what else could cause missing vsc and vsetup voltages only when logic/control board power cable from y board is connected?
                                          and when power to logic is disconnected from y board...vsc and vsetup voltages are good
