Police Body Cam had wire ripped out
  • Doc38343
    • Apr 2015
    • 402
    I got this in trying to help my local police dept save a couple of tax dollars.
    Officer was in an altercation and the suspect ripped his body camera off his shirt. It pulled loose the wires and I soldered it back on but i need to be sure they are correct in position.
    Red = tip
    Blue = 2nd from tip
    Yellow = 3rd from tip
    (The officer thinks that is right he had opened it and they tried to re-attach)
    4th from tip goes to ground AND there is a mic but it is glue sealed so i can't tell if it runs back to the cam or just to the DVR that attaches to their belt. I think the wires are Audio, video, power and ground.
    No brand name but WAY over priced in my opinion. Therefore I'm trying to fix it for them.
    Pics attached
  • budwich
    • Jul 2015
    • 3097
    Re: Police Body Cam had wire ripped out
    best way might be to get the officer's "friend" (ie. partner) unit, remove the cover and do a resistance / continuity measurement back towards the end
    • petehall347
      • Jan 2015
      • 4450
      • United Kingdom
      if there is no power there nothing should be harmed by trying it .
      wires look right to me .
      • Doc38343
        • Apr 2015
        • 402
        I'll get him to stop by. There are no shorts I just wish we were sure. It does get 3v from somewhere to run the 25X40CL memory chip and the oscillator. Other side of the board just has the video sensor and 5 or 6 caps. (I don't want to get it dirty) I tried to follow the VCC in reverse but the solder mask is just to thick and the parts too tight. They consider it a loss anyway so I'm for trying it.
        • wnlewis
          New wire for my RDE3340 Whirlpool electric range
          by wnlewis
          OK. I got the rocker switch figured out thanks to the good advice on this forum.
          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
          This is a Whirlpool RDE3340 electric range.
          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
          Where may I find parts...
          01-08-2025, 11:21 PM
        • emeskay
          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
          by emeskay
          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
          08-06-2024, 07:13 AM
        • technicalspecialist
          Vintage fan repair, copper wire question
          by technicalspecialist
          I currently have a customer's vintage fan on the work bench to repair.
          It uses an induction motor with 4 poles. One of the poles is open.
          I couldn't find the break so i cut off the original wire.
          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
          The enamelled copper...
          03-16-2023, 12:54 PM
          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
          by sam_sam_sam
          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
          12-16-2023, 08:39 PM
        • kalemaroni
          Dell DC Brown wire
          by kalemaroni
          There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
          08-26-2025, 10:10 AM
