Nexus NX3202 TV - won't turn on, power supply making noise
    So I just picked up a free Nexus NX3202 TV. When I plug in the TV I see the red standby LED, and when I press [power] the LED turns blue but instead of powering on the TV the power supply emits a popping sound. I attached a picture of the sound when recorded and viewed in audacity and you can see that the pulses don't follow any particular order. It sounds as if something is shorting out, and it seems to be coming from around the transformer. I highly doubt its a relay making the noise. Tomorrow I'll measure the voltages from the power supply and attach a picture of the back of the power supply board. Any idea what could be shorting out? Could it be the transformer?
    Re: Nexus NX3202 TV - won't turn on, power supply making noise
    A quick initial test is to use your meter in diode mode and test the diodes and mosfets for any problems. Set powered off.
    What voltages do you have on the power supply connectors and are the connectors labelled eg. 5V, 12V, GND etc.
      You have checked for bad connections at transformer. Maybe lift transformer and inspect bottom of transformer.
        I have attached better pics of the power board. Here are the voltages:
        Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
        1 - On - zero – 4.90v
        2 - GND – GND - GND
        3 - 5v - 4.93v – 4.92v
        4 - Not Labeled - GND - GND
        5 - Not Labeled – GND - GND
        6 - Not Labeled - 0.48v – 0.46v
        7 - Not Labeled - 0.48v – 0.46v
        1 – Not Labeled – 0.48v – 0.46v
        2 – Not Labeled – GND - GND
        1 – 24v – zero – 24v
        2 - 24v – zero – 24v
        3 – GND – GND - GND
        4 – GND – GND - GND
        1 – GND – GND - GND
        2 – GND – GND - GND
        3 – GND – GND - GND
        4 – GND – GND - GND
        5 – 24v – zero – 24v
        6 – 24v – zero – 24v
        7 – 24v – zero – 24v
        8 – 24v – zero – 24v
        Everything looks fine, except for the 0.48 volts on some of the unlabeled pins, that seems suspicious. I'll check that transformer in a second.
          https://www.badcaps.net/forum/attach...5&d=1500963234
          The picture is way too small to see anything.
          It looks like the main sends out the PS-ON to turn on the rest of the power supply but not the BL-ON, the Dimming control signals (the unlabeled pins).
          We need the pictures of the whole backside of the TV showing all the boards also.
            OK, I have some more pics. Unfortunately most of the boards a covered in shielding so they aren't visible, but I did label them so you could see which one corresponds to the pics in my first post. I also attached pictures of another board I forgot to include earlier.
              https://www.badcaps.net/forum/attach...4&d=1501125149
              If you look at that inverter board, you will see the connector has pin names for it, take the reading of each pin and report the readings, make sure to provide the pin names so we can easily find out what signals and Voltages are missing.
                VCC – zero – 24v
                VCC – zero – 24v
                VCC – zero – 24v
                VCC – zero – 24v
                NC – Not Connected
                GND – GND - GND
                GND – GND – GND
                GND – GND – GND
                GND – GND – GND
                NC - Not Connected
                SEL – GND -GND
                E-PWM – zero – 3v
                I-PWM – GND - GND
                ON/OFF – zero - zero
                  OK, you do have the 24VDC to run the inverter board and you also have the E-PWM dimming control signal from the main board bit you do not have the ON/OFF (BL-ON) from the main board to turn on the inverter circuit, so something is wrong on the main board.
                    Hmm, so you think the noise I was hearing has nothing to do with the problem?
                      Nope.
                        Ok, thanks for helping me narrow it down to the mainboard. I'll start checking components.
                          Just made a big discovery. The unlabeled pins on the Power supply are labled on the corresponding connector on the main board, and they are supposed to supply 12 volts. That means there is an issue with the 12 volt rail because it is only supplying .48v.
                            Have you checked the 12V line with the set off with your meter on ohms to see if there's a short or very low resistance on any of them.
                              It looks like the two transformers (12&24 volt) primaries are connected together, so If you have 24volts, check the dual diode for the 12 volts, and that (resistor/jumper wire?) and coil between diode and output connector.
                                I measured the voltage coming from the output pin of the dual diode that supplies power to the 12v line and it is fluctuating around 100mv, although I still have a steady .46v on the 12v line but that's probably because of all the capacitors.
                                The other pins of the dual diode each connect directly to separate transformers. So my question is, do you think the dual diode is bad or could the problem be with the transformers? The dual diode for the 24v rail is connected to the same transformers and its working fine so I'm leaning towards a bad dual diode.
                                  Remove the diode and test out of circuit. What's the part number of the diode.
                                    Check the resistance of the transformer secondary to make sure its not open, to check the primary you would need to isolate at least one of the pins from the the trace as the 24 volt primary is connected in parallel with the 12 volt primary
                                    It looks like they take one winding from each transformer secondary to supply one side of the dual diode, so I would think if there is 24 volts, 12 should also be there unless the diode is open or the + 12 has a short at its output
                                    I would check the dual diode on the 24 volt side also, half of it could be bad?
