Sony Bravia KDL - 46EX650 top part of screen blank or lines
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    This problem apparently started intermittently then gradually became permanent.
    I tried reseating the LVDS and T-Con cables at the Tcon board but it didn't help. I suppose I could strip it down further and try reseating the cables at the other end but I thought Tcon cable problems cause vertical lines?
    Or is this tab bonds / chip on flex problem yet again!
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • CapLeaker
    Leaking Member
    • 8221
    Re: Sony Bravia KDL - 46EX650 top part of screen blank or lines
    seems like on the first picture is a bar, on the second picture there are lines, probably sluggish to respond. My bet are on the tab bonds.
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      since i have seen lots of sony tab issues, i would look there first.
      give the bezel a twist and see if it alters the issue.
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Trying to twist the bezel had no effect.
        I got the bezel removed and also the metal shield or cover around the edge of the LCD panel. There are six tab bonds at the bottom, pressing on each of these make absolutely no difference to the picture at all
        There seems to be a plastic cover or edging all around the LCD panel and I can not see any evidence of tab bonds on the sides of the panel unless they are under the plastic but I am not sure how I could remove that as it passes behind the six flexes at the bottom of the panel
        See pics
        Rich
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          if you disconnect one side of the t-con at a time, is the fault still present on either half?
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            OK mate.
            With the right hand of the screen disconnected, the left hand side still has the flickering horizontal lines same as before (actually I didn't check closely if the height of the flickering area is the same but think it was)
            With the left hand side disconnected, the right hand side now shows more of the image than before (compare the attached pic with the one on post #4 - you can now see the icon above the Audio icon) and there are no flickering horizontal lines, just a blank grey area at the very top of the screen
            Rich
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              it's hard to see, but is there a matching grey bar on the top and bottom of the screen in that pic. maybe feeding it a source can make things look a little clearer.
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                Sorry mate the photo wasn't good. What you see on the screen is a menu from a MAG250 box connected to HDMI on the TV.
                There is no grey bar at the bottom and it seems the grey bar at the top is a 'red herring' just part of the menu screen from the MAG250 because when I attached another video source I actually get a perfectly good picture full screen height with just the one TCON cable attached.
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  With just the other TCON cable attached or with both I get those horrible flickering yellow lines at the top of the screen,
                  Is this indicating i have a TCON fault and not a panel fault?
                  I suppose I could arrange to connect the 'good' TCON cable to the other side of the panel, the leads are too short but if I let the mainboard and Tcon board hang free I could do this though it may be a bit awkward to see the screen at the same time. If I went to that effort would that prove anything we don't already know?
                  Rich
                  • dicky96
                    Sun Seeker
                    • Mar 2017
                    • 1825
                    • Spain
                    Oh here is a photo with just the other Tcon cable attached. Different video image because I could not navigate to the calendar icon as i could no longer see it! but that is not really relevant.
                    I did try connecting the 'bad' side of the screen to the 'good' Tcon cable
                    At first I got vertical lines all down the 'bad' side of the screen but interestingly there were no flickering horizontal bars. Of course I had not seated the tcon cable properly. After fixing that I just got a completely blank screen with no flickering lines or anything else. So I guess it is not as simple as that, ahh well...
                    Anyway it doesn't appear to have done any harm when I put the cables back how they were I was back to square one.
                    • attainteddragon
                      • Apr 2013
                      • 764
                      • australia
                      looks to me that you have another bad panel. it may even be a side cof chip but not totally sure about that.
                      you know which side is playing up, you can have a prod and play to see if you can isolate the fault a bit better. you might get lucky and find something getting hot on the panel driver board, but i would not hold my breath on this one unfortunately.
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        OK thanks mate. I can only see tab bonds at the bottom of the panel, not on the sides
                        Will check for something getting hot.
                        • dicky96
                          Sun Seeker
                          • Mar 2017
                          • 1825
                          • Spain
                          Nothing getting particularly hot on the narrow boards that the tab bond cables connect to though it's a bit hard it tell as any IC components are on the underside of the boards.
                          I definitely can't see any side tabs on this panel.
                          I also tried swapping the Tcon cables around to eliminate a possible bad one - it makes no difference so they are both OK.
                          I seem to have something missing in my knowledge here. I am really confused how I am supposed to diagnose a TCon fault from a panel fault.
                          I am also puzzled by the results of disconnecting one TCon cable at a time, and how you interpret them.
                          To be clear, I have the following situation.
                          Left cable only attached = left half screen image with lines at top
                          Right cable only attached = right half screen image with good picture
                          Both cables attached = full screen image with lines at top on both halves
                          It seems to me, if with both cables attached I get lines on at the top of the right hand side of the screen, but with just right hand Tcon cable I get a good image on that side.... then it suggests some signal coming from the left hand TCon cable is making the right hand side go bad - yet you say these results prove it's a panel fault.
                          So why am I misunderstanding this?
                          I am not questioning your knowledge here Mr Dragon, you obviously know more than me, I am a learner. I just can't get my head around the logic of the diagnosis and I really want to understand this.
                          Is there some explanation or tutorial somewhere of the method and reasoning to correctly diagnose a faulty panel from a faulty Tcon?
                          Rich
                          • attainteddragon
                            • Apr 2013
                            • 764
                            • australia
                            Rich
                            i am only a learner too, so my knowledge is very minor compared to some others around here.
                            think of it this way, when you only have your right hand side hooked up all is great in the world, but at any time when you have your left hand side hooked up, your panel no longer wants to play with anyone else. when you get a signal through the bad chip on that side of the board, whether it is something short or open, it ends up taking priority over the rest of the panel. guessing it is really due to the needs of the failed part, so the panel as a whole suffers. that is why one side works properly without the bad half in play. nothing getting dragged down.
                            the only way to really tell what is exactly wrong would to be to put your boards into a known good panel, or scope the lvds signals that go into and out of the t-con.
                            i believe that last time you were able to locate the offending tab chip that was playing up. this time not so lucky, there is always a chance that there is a component on the panel driver board that has failed, but outside of a ceramic cap going open, i have seen very little in the way of anyone doing much in repairs on these boards.
                            there is also lots of cases of water damage on these boards due to cleaning with an overly wet sponge when the driver board is on the bottom of the screen.
                            hope this is coherent enough, havn't finished my first coffee yet! my bad.
                            • Chrissygizmo
                              Sony KD-55XG9505 lines on screen problem
                              by Chrissygizmo
                              Hello again everyone,
                              This is my latest mission, to try getting this Sony tv back to normal working order…
                              I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                              02-19-2025, 11:31 AM
                            • ggil44
                              Sony XBR-65X750D Horizontal lines bottom of screen
                              by ggil44
                              Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                              05-30-2023, 07:51 PM
                            • Stanley1843
                              by Stanley1843
                              06-29-2024, 11:54 AM
                            • dvu0627
                              Sony XBR65X900H TV with Horizontal Lines right half of screen
                              by dvu0627
                              I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
                              I replaced the T-Con board but the lines are still there.
                              I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
                              Thank you for the help....
                              02-05-2023, 03:39 PM
                            • jeyoung12
                              Samsung QN50Q60t lines on screen
                              by jeyoung12
                              Hi all
                              I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                              My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                              This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                              It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                              So....i don't know what end of the C ribbon to work with...
                              02-26-2024, 10:38 AM
