Sharp Aquos LC-60LE652E - Blank screen, no sound, steady blue LED
  • Martin_Silberkuhl
    • Jul 2017
    • 25
    Hi there,
    I've a problem with a Sharp TV.
    If I plug-in, only the turned "V" lights blue steadily. I cannot switch into stand-by, not with the power sensor button on the front, not with the remote control. Remote control ist working because if I press a button the "V" starts to flicker. If I connect my laptop via HDMI, no picture and no sound appears.
    Following actions I did, but had no effect:
    - hold VOL down and INPUT buttons at the same time, then press POWER
    - measure all voltages on the right connector of the psu
    >result: can measure all voltages with a dvm, except PS_ON, BL_ON (0V), PWM1 and DIM, because not knowing what to expect)
    - measure all voltages on the top connector which supply the backround LEDs
    >result: no voltages between LED+ and LED-, but if I disconnect and drive the LEDs with an external psu, the LEDs are working
    - measuring all diodes on the psu
    >result: all diodes are OK
    - looking on all capacitors
    >result: seems to be OK, nothing is bloated
    Any idea?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Sharp Aquos LC-60LE652E - Blank screen, no sound, steady blue LED
    A good start is to give the voltages on the connector. The label for the pinout is at the top of the photo.
    • Martin_Silberkuhl
      • Jul 2017
      • 25
      OK, here we go:
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        You have no backlight or DIM voltages so the backlights won't come one. You should have sound and be able to see a picture using a bright light source (torch) shone onto the screen and looking carefully.
        If you disconnect the main board and power up, do the backlights come on. If not I would with the mainboard still disconnected, jumper the 5V standby to BL_On using a 1K resistor and a second 1K resistor to jumper 5V standby to PS_ON and see if the backlights then come on.
        • Martin_Silberkuhl
          • Jul 2017
          • 25
          First issue I can test tomorrow.
          Second issue "jumper...." I've done (see photo).
          After jumpering I can measure 5V on BL_ON and PS_ON, but no effect, so no
          backlight.
          Also the voltages on LED1+/LED1-, LED2+/LED2-,... are 0V.
          Further suggestions?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            What value do those resistors (above photo) measure with your meter?
            When you initially power on and come out of standby what voltage do you have on the led connectors. Initially it may peak and then drop suddenly.
            If no voltage then with the power off, check all the diodes with your meter set to diode mode.
            Can you post a picture of the underside of the power supply.
            • Martin_Silberkuhl
              • Jul 2017
              • 25
              Both 1kOhm, as you suggest.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                The colours in the photo look like brown, grey, green, black, silver
                • Martin_Silberkuhl
                  • Jul 2017
                  • 25
                  When you initially power on and come out of standby what voltage do you have on the led connectors? Initially it may peak and then drop suddenly.
                  0V
                  All diodes have about 0,46V forward voltage, except the 1N... . They have about 0,6V (that's normal).
                  D402 and D401 have 0,2V and D207 0,3V.
                  Is attached
                  • Martin_Silberkuhl
                    • Jul 2017
                    • 25
                    OK, the value of resister is brown, black, green, brown, brown -> 1050 Ohm
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      What are the IC numbers as given on the IC's
                        0V
                        Is attached
                        Are you saying you have 0V at the LED+ PIN of the LED connector with ref to the chassis GND? Please clarify.
                        What DCV do you get by measuring between the two legs of cap C901?
                        • Martin_Silberkuhl
                          • Jul 2017
                          • 25
                          Hey Dick,
                          the ICs U901A and U901B are both BD9483F (White LED Driver for large LCD
                          Panels - DCDC Converter type).
                          • Martin_Silberkuhl
                            • Jul 2017
                            • 25
                            Hey Budm,
                            I measured the 0V between LED+ and LED-, not with ref to the chassis GND.
                            The DCV between the two legs of cap C901 is +90V.
                            • Martin_Silberkuhl
                              • Jul 2017
                              • 25
                              Hey Dick,
                              I tested it in the morning and I have no sound and no picture, also not using the torch.
                              • Martin_Silberkuhl
                                • Jul 2017
                                • 25
                                Hi there,
                                I really don't know, but because I can't switch the tv in stand-by I suppose the failure on the main-board. But let's stay in this systematically mode.
                                  Hey Budm,
                                  You need to use chassis GND.
                                  That 90V is the Voltage for feeding the Voltage Boost converter circuit to supply the Voltage to run the backlights LEDs.
                                  You also need to do this test:
                                  1) Turn the TV off.
                                  2) Leave the DCV meter BLACK PROBE on the chassis, and Red probe on the LED+
                                  3) Keep an eye on the TV and see how high the Voltage goes up to and then wait about 5 seconds to see if it goes back down to 90V.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    Hi there,
                                    Quite true i was forgetting that the tests were with mainboard disconnected.
                                    What voltage do you have on Pin1 of the two IC's BD9483. The data sheets says between 11V to 35V This is with the jumper resistors in place as described in an earlier post.
                                    • Martin_Silberkuhl
                                      • Jul 2017
                                      • 25
                                      Hello guys,
                                      hope you had a good weekend. The following things I have done in the morning:
                                      @budm
                                      1) Turn the TV off.
                                      I had done all three steps. When I switch on the TV, the voltage goes to exactly 90V and stays continuously.
                                      @dick
                                      You did not forget.
                                      I measured 12,12V on both IC's Pin 1.
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        12V is within the operating voltage range for those IC's
                                        What voltage do you have on Pin 2 of each of them which should be >2V
                                        I would check all the mosfets/diodes around those IC's. The 4 above and the 4 below the IC's
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
                                        • foxyUK
                                          Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                          by foxyUK
                                          Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                          The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                          There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                          10-22-2024, 10:27 AM
