Sharp Aquos LC-60LE652E - Blank screen, no sound, steady blue LED
  • Martin_Silberkuhl
    • Jul 2017
    • 25
    Re: Sharp Aquos LC-60LE652E - Blank screen, no sound, steady blue LED
    No, what I mean is, what is the next step?
    Without a circuit diagram it's not really easy. Normally I would check the voltages on all ICs, but I don't know which voltages.
    What would you do?
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      #42
      I would say at this point without a schematic I would be looking for a replacement main board or for one being sold with a cracked screen.
        May be you can use ADIM (Analog Dim) control pin and set and forget type so the LED current is set to as low as possible, it will be cheaper than new main board and use it until the main board fails completely.
        BTW, the spec sheet of the IC does not explain how to choose between the PWM and ADIM function. The app notes schematic shows ADIM pin is terminated with a cap to GND for using PWM DIM. You may have to do experiment to see how to use ADMIN (3V is the max level)
        • Martin_Silberkuhl
          • Jul 2017
          • 25
          Hey guys,
          thank's for helping me. I try to get a main board. If I have tested, I'll come back with the results.
          • tijntijn
            • Oct 2017
            • holland
            #45
            hallo everybuddy,
            i have the same tv lc60le652e no sound no picture it does power on my qwestion is have you fixed the problem by replacing the mainboard ?
            thanks have a nice day
            tijn
            • khizarnld
              • Feb 2018
              • The Netherlads
              #46
              Originally posted by Martin_Silberkuhl
              Hey guys,
              Good Day.
              I have the exact same model sharp with with the same problem, what have you done with your tv, did you succeeded repairing it, i would appreciate if you let me know what happened to your tv. Maybe you have some info helping me getting my tv back, eager to hear from you,
              • vdoru77
                • Jun 2018
                #47
                Hey guys,
                Hi there,
                I don't know if it helps but I had the same problem and I solved it by replacing the mainboard.
                • scubacamper
                  Sharp Aquos LC-70C6400U Half Screen Dark
                  by scubacamper
                  I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                  Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                  when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                  05-03-2025, 12:19 PM
                • sefoster
                  Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                  by sefoster
                  I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                  11-20-2022, 09:29 AM
                • jonah1024
                  Sharp Aquos LC-40UG7252E LCD TV burn in?
                  by jonah1024
                  Hello!
                  I'm a few days old into this TV screens repair universe so please bear with me.
                  Recently, and all of a sudden my 40ā€ 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                  - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                  - I did a factory reset as well...
                  07-16-2024, 04:23 AM
                • klassic
                  Sharp Aquos LC-60LE635E three blinks
                  by klassic
                  Hi community,
                  I will describe my problem with a TV in those short following terms to be the most precise :
                  What i have :
                  power board DPS-162KP-1
                  main logic board QPWBXF733WJN2
                  symptoms :
                  white led light logo at startup,
                  after 2 minutes, blinking 3 times a row, repeating
                  no backlight (and apparently no picture, checked panel with flashlight)
                  no startup sound
                  powerboard investigations :
                  1-2 PNL : 0v
                  3-4 GND
                  5-6-7-8 UR : 13.15v
                  9-10-11-12...
                  10-24-2023, 01:39 PM
                • foxyUK
                  Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                  by foxyUK
                  Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                  The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                  There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                  10-22-2024, 10:27 AM
