LG 47LN577V backlight turns off
  • PowerAmpFreak
    • 982
    • Sweden
    This LED-TV, LG model 47LN577V turns on backlight and shows logo but within one second turns it off again.
    The backlight control signals are OK from mainboard, also the dimming control is OK.
    So this happens internal the PSU/Led driver board.
    Since the board is quite cheap I bought a new one, but exactly the same problem is still there.
    So, I guess this all relates to crappy led strips giving either too high or two low current for the led control to be happy?
    I will try to power up the led strips by an external powersupply and see if it looks normal.
  • zomi
    • Nov 2011
    • 512
    Re: LG 47LN577V backlight turns off
    Classic bad backlight..
    You will have a bad led or 2 somewhere
    happy hunting
    • PowerAmpFreak
      • 982
      • Sweden
      IMO today's LED-TV's are crap. Long live the plasma technology even if it was bulky and expensive to produce.
      But it last long.
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
      • frannyjunk
        Hisense 40H4F no backlight but turns off after splash screen
        by frannyjunk
        So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
        TIA.
        09-24-2025, 10:59 AM
      • Stephen
        A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
        by Stephen
        Hello, got a weird MacBook Air here
        board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
        08-23-2023, 09:12 AM
      • kalemaroni
        Samsung QE50Q60AAUXXH turns off as soon as backlight turns on
        by kalemaroni
        Plugging the power in will turn on the backlight after about 5 seconds and then immediately shuts down.
        If I unplug either of the two cables with the yellow outline in the picture the backlight stays on and the startup sound plays but no image. Any ideas how to proceed with this please?
        07-16-2025, 04:53 AM
      • ohren
        Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
        by ohren
        I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
        The setup is basically:
        Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
        Transistor is switching the 3.5 V supply on the power board....
        12-05-2024, 11:10 AM
