i have this sharp smart tv. in my shop i can get it to connect to my wifi. bring it in the house to my daughthers room and it shows the wifi networks but want connect. the routher is only about 3 feet from the set thu a wall. set has been hanging up a lot, remote will only tab side ways sometimes , have changed the logic board and both do the same. tv 200 feet away will find wifi and log on 3 feet away sees wifi but does not connect help please
sharp lc-50lb371 u
by KYBOSHI picked this one up today.
Previous owner says no signs of life.
TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
The TV model is QN65LS03BAFXZA - version: CB06
The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
Will keep you all... -
by An-klammHello!
I have a TV that I can't get any further with.
It is a Samsung UE 55HU8590 with one connect box.
When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
Since the TV works without ocb, I assume that it can't be the PSU?!
I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
Is there... -
by EazyBoneI got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small... -
by jason123Hello all,
I have a 75" QLED TV that I love. This morning ,as I'm watching a show, it shut off and no luck turning it on. Unplugged and waited an hour, and no activity. No clicking "On Relay" like it normally does.
I see many have issues with the mammoth external one connect box. I was going to buy one, but used on eBay they're in the $300 range with no returns. Is there a way to know if it's TV or One Connect?
Thanks -
by AlexVGHi,
I came across with
SAMSUNG UE65HU8500
ONE CONNECT BN41-02135
Chassis GOLF_UHD_1MP_JACK
TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
Moreover, on the main is written A5V. However, cable connected this pin to the GND.
Maybe somebody have an experience with the same issues?
I need your help.
Thank you.... - Loading...
