panasonic tx-p55vt30 and tx-p55st60 problems.
  • dj01fad
    • Sep 2014
    • 92
    • romania
    Re: panasonic tx-p55vt30 and tx-p55st60 problems.
    A board is OK; tested on another TV it works perfect. is it possible to have a SS board problem?
      SS board failure is rare, but can happen
      • dj01fad
        • Sep 2014
        • 92
        • romania
        VT30: it was SU board...
        • tw2005
          • Oct 2011
          • 6458
          Yep, that can do it, but what was blown? Any buffers shorted? And no 7 blink?
          • dj01fad
            • Sep 2014
            • 92
            • romania
            Yes, no shorts and no 7 blinks; maybe it was something in the upper chip and the whole screen was bloked;
            now... for the ST60... I did not reveive the 42" board, but I found a board from a 50ST60B; it's an UK model, and I was wondering if it has dvbc... so... if someone knows something... on the other hand I found a 50GT60 board that I can fit in the TV as the housing is the same... I don't know what to do.
            • tw2005
              • Oct 2011
              • 6458
              Again, no photos and very little "Technical" info. How about part numbers, version suffix and images? What does a GT have that a ST may not that may trigger a SOS? Eg Fans or Speakers?
              • dj01fad
                • Sep 2014
                • 92
                • romania
                #27
                my phone's camera is broken, so until friday no photos...
                my TV's board is TNPH1045 - TXN/A1AXVE;
                the UK board is TXN/A1WZUB
                this one: http://www.ebay.de/itm/TNPH1045-1A-P...UAAOSwWdZZYiEZ
                the GT60 board is this:
                http://www.ebay.de/itm/MAIN-BOARD-TV...0AAOSwZJBYBPi~
                both models ST60 and GT60 have SW and no fans.
                • tw2005
                  • Oct 2011
                  • 6458
                  Tough gig this, hard to find manuals too. The GT is a different board print. It may bolt it and it looks like it will have similar connections, some in different postions though so what about the faceplate and also the LAN port is in a different spot so it that is a hole pressed out in the rear panel that won't line up. Sometimes the holes are there but they use different stickers to cover up one that are redundant.
                  The UK board has me interested in the tuner setup? Can't say I've seen that twin connection before which yours has. I'd be leaning towards finding te right one or one from the same region , different size and swapping some eeproms .
                  • dj01fad
                    • Sep 2014
                    • 92
                    • romania
                    #29
                    I found another board from a 42" but the seller cannot tell me the suffix or anything about it... he's a farmer . it's 50 euros...
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                      11-20-2024, 08:52 PM
                    • jean luc ferre
                      laptop hp g72 b52sf screen problems
                      by jean luc ferre
                      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                      i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                      06-07-2025, 03:27 PM
                    • Hondaman
                      USB problems?
                      by Hondaman
                      Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                      (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                      I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                      08-12-2024, 03:26 PM
                    • clabr
                      Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                      by clabr
                      Need help to solve some problems with this laptop.
                      After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                      After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                      Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                      Before this had happened I observed some other problems:
                      When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                      12-02-2021, 08:09 AM
