Little Help with Sharp LC-80LE642U
  • Robottom
    • Jun 2017
    • 41
    Re: Little Help with Sharp LC-80LE642U
    BUMP
    Does any one know what / where these chips are that Martino mentioned?
    If there's an easy fix of any kind, I'll give that a try but pretty much tomorrow is the end game for this thing. I promised we'd have our TV back by then, so it's off to Costco for a new one and parts for sale after that.
    Thanks,
    Tom
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      #42
      Have you tried to bring on the panel leds without the mainboard connected to ensure they stay on, by jumping PS_ON to standby voltage using a 1K resistor
      • Robottom
        • Jun 2017
        • 41
        No, I asked if there was a way to do that in my original post, "Fool the power board" but didn't get any feedback.
        Will go try that now and let you know what happens.
        • Robottom
          • Jun 2017
          • 41
          Nothing, the power board doesn't even try to output to the LEDs.
          There must be some other signal from the main board that tells the power board everything is OK. Do you know what other signals from the main board I would have to fake?
          And as for being no expert, I'm sure that I have you way beat, thanks anyway!! :-)
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            #45
            Taking a look at some earlier readings given on the power supply it looks like the standby voltage is BU5V (Pin15). So with this jumped (using resistor) to PS_ON (Pin14) do the leds come on. Normally there is another connection such as BL_On/OFF but I cannot see anything marked like that.
            When you do jumper BU5V to PS_ON what voltage do you have at the STB pin (Pin 24)?
            • Robottom
              • Jun 2017
              • 41
              With BUSV pin 15 jumped to PS_ON pin 14 through 1K Ohm resister, I'm still not getting the LEDs to turn on, and measuring only 14 - 15mV at STB pin 24.
              • Robottom
                • Jun 2017
                • 41
                Just trying a couple of things to get the LEDs on using the power board, I went back to this idea that I talked about earlier: See attached pic.
                This guy actually powers up STB as well as PS_ON from BU5V but no resistor.
                Anyway same as what you said he's also powering something else PWM1.
                But I don't see anything on this power board with those markings or the markings BL_ON you mentioned.
                I tried powering STB through the resistor from BU5V too and still same, no LEDs lighting up.
                There is a PNL_POW but I haven't tried that yet.
                His instructions require a step order of powering up that I don't have switches for not to mention no idea what might blow up if I do.
                  It looks to me that he is referring the 'STB' to be the same as 'BL-ON' which may be the case for the Sharp TV.
                  I would never try to force on anything without using the resistors because if you made the wrong connections you can cause more damage, the resistor is used to limit the current.
                  The PNL-POW is the control signal from the main board to turn on the switched 12V (PNL-12V) for running the T-CON board, you do not need that signal to test the backlights circuit.
                  • Robottom
                    • Jun 2017
                    • 41
                    Question... Assuming that I can get the power board to light the LEDs without being connected to the main board, where do I go from there?
                    I've already replaced all three boards and have exactly the same symptoms as from the beginning.
                    Assuming that the boards are OK, something else must be wrong.
                    Example: overcurrent from the LEDs or possibly LCD panel error of some kind via TCon. (would mean that the flashing icon 1 short 1 long is misleading).
                    Are there any chips or components in the LCD panel section that I am not seeing?
                    • Robottom
                      • Jun 2017
                      • 41
                      With
                      BUSV (pin 15) jumped to PS_ON (pin 14) through 1K Ohm resister,
                      STB (pin 24) jumped to PS_ON (pin 14) through 1K Ohm resister and
                      PNL_POW (pin 16) jumped to PS_ON (pin 14) through 1K Ohm resister
                      I get a short flash of the LEDs at power up and again at power down.
                      Nothing seems to keep the LEDs on longer than a short flash.
                      Are there any other tests than powering the strips with the LED tester that I can run on the LED strips to be 100% sure that they're not one and only problem?
                        One end of those resistors should go to BU5V pin, not PS-ON pin.
                        May be you should buy the LED tester.
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          #52
                          Agreed,it's not the panel as you tested that.
                          I have this one, works awesome.
                          http://www.ebay.ca/itm/LED-LCD-TV-Ba...QAAOSwnNBXYlGC
                          A 80" tv is worth the effort you put into it and then some.
                          Maybe pick a el cheapo tv up from craigslist for the time being to keep the better halve at bay?
                          Proud owner of dozens of broken TV's and many,many,many boards.
                          Our website and passion:http://hollenhundshepherds.com/
                          • Robottom
                            • Jun 2017
                            • 41
                            Thanks for the encouragement, I'm pushing back.
                            I finally decided to hire someone to come out and help troubleshoot.
                            Drops another $50 into the bucket but if I can get it working beats the heck out of $2K or more.
                            I bought the tester several posts back, the exact same one in your link.
                            That's what I used to test and post the results that the LED strips were reading 174 - 175VDC.
                            ALSO .... I'm still curious about your (Martino) previous comment about chips burning up, pulling ribbon cables to test, getting half a screen working and being an easy fix.
                            Could you please go back over that again and let me know where / if there is some component / chips in the LCD panel that might be the problem.
                            • budwich
                              • Jul 2015
                              • 3097
                              read up on the numerous sharp 70 threads that provide LOTS of "cable pulling" examples / discussion. Look for "corner cable" posts/discussion... hint, there are cables in the lower corner and each side that connect the lower edge boards to the side boards. 2 5 flash code is common BUT the system isn't always good as to what codes are output. It is rather strange that you are unable to force the set to come up with back lights on especially with the amount of card changes that you have done... assuming those are good.
                              • Robottom
                                • Jun 2017
                                • 41
                                I have been scratching my head and wondering what edge boards and corner cables were.
                                I found this (https://www.badcaps.net/forum/showth...+cables&page=6) scroll down to #105 - 106, and some other threads which I think explain but I don't have any of those boards or cables.
                                Here's what my LED back panel looks like and here's what my LCD panel looks like. Although this pic is just one corner, believe me, there are no connections or boards except for the ones coming from the Tcon to the LCD.
                                I paid a tv tech to come out to my house and troubleshoot. He said the new main board that I received had exactly the same problem as the one that I need to replace. I've sent that one back to Secure Core (who by the way gets kudos from me, free return and full refund, they didn't have another in stock but ...) I have another one on order, should be here Tuesday. I'll post then hoping that turns out to be the problem, regardless, I had to promise it's the end of the line win, lose or draw. If it's not back on the wall working Tuesday night I'm off to Costco to buy a new something or other.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #56
                                  Is that your wife's side of the bed you got the panel on?
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    :-) but I think you are looking at the wrong side / face.
                                    there are edge boards on the sets in some form. Just as you see the bottom edge boards connected to the panel with "tab driver flex cables", there are similar cables connecting the sides either to a board or to a long flex cable that act like a board.
                                    Anyways, it must be tough sleeping with the TV... :-)
                                    • Robottom
                                      • Jun 2017
                                      • 41
                                      No but she's threatening to make that one my permanent bedroom.
                                      • Robottom
                                        • Jun 2017
                                        • 41
                                        I only see a black rim around the LCD section.
                                        I haven't taken that apart but have inspected it pretty carefully and there are no visible boards or cables.
                                        Is it possible that the edge panels and cables are integrated into the LCD Panel Module Unit on this model?
                                        Have a look at the Cabinet Layout attached.
                                        These pages are extracted from the LC-80LE642U Service Manual
                                        I don't see anything that I don't recognize in the PCB or Parts lists either.
                                        At least the TV isn't complaining :-)
                                        The wife on the other hand ......
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          The reason that there is no listing for the boards is that they aren't replaceable as there is bonded cabling between the board and the panel which is a "one time assembly / manufacturer". Anyways, I would look closer at the edge especially going from the tcon to the panel at the bottom. Your issue may be related to how the edge boards are interconnected which could be good or bad depending.
                                          • carrzkiss
                                            Cyberpower cps1500avr not charging batteries
                                            by carrzkiss
                                            Hello, all.
                                            Cyberpower Battery Backup Unit.
                                            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                            Checking the voltage, it was down to 22v.
                                            I quickly removed everything...
                                            06-15-2024, 02:10 PM
                                          • howardc64
                                            Where do repair shops buy MB replacement batteries?
                                            by howardc64
                                            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                            07-25-2024, 10:42 AM
                                          • edugimeno
                                            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                            by edugimeno
                                            Hi There!
                                            I'm trying to help my friend who owns a restaurant be just bought.
                                            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                            It's stuck using, I guess, the 2 sided tape that comes with the strip
                                            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                            09-05-2024, 09:34 AM
                                          • Astonished
                                            Fixing the Charge Circuit of the Batteries of the DC Motor
                                            by Astonished
                                            Hi friends of electronics
                                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                            Please help me fix this circuit.
                                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                                            01-28-2025, 06:24 AM
                                          • piernov
                                            Reminder: rules and organization of this section
                                            by piernov
                                            Activity on this forum has been increasing steadily and the workload for the moderation team as well in order to keep the place clean, so please make an effort to keep it organized.
                                            I've been deleting more and more posts that make a mess, so take a minute before posting to make sure you make a proper request/offer.
                                            Reminder about the rules and the organization of the "Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals" section.
                                            This section and its subsections are about the following classes of devices:
                                            • Desktop computers
                                            • All-in-one
                                            03-31-2023, 06:17 AM
