Toshiba 42C3000A screen or tcon
  • maxvalutech
    • 804
    • australia
    Turn on with blue screen and all looks ok, start DVD player and writing looks ok, play picture and polarisation very evident. Also bring up set menu for a minute or so and faint image retained for a long time. I'm thinking screen had it and that's disregarding green vertical line on far lhs. Thoughts ?
    Re: Toshiba 42C3000A screen or tcon
    Reset the cables on T-CON first, if still not fixed then check T-CON GAMMA Voltages.
    History of this TV?
    • maxvalutech
      • 804
      • australia
      Thanks budm will do that and I did download the spreadsheet a little while back. Got this and another from chap with youngish family so I think it has had a bit of use alright but no other info except he said had adjusted brightness down and other settings to get a watchable picture -:I have set it back to standard normal. Haven't had back off as yet.
      • maxvalutech
        • 804
        • australia
        Well I took the back off this very heavy set and must say I haven't seen anything quite like. The tcon must be under the main and the panel that those boards are on - a fair bit of dismantling. Both ribbon cables head that way and I can't see where they actually end up. So if anyone has experience with this would be pleased of confirmation. It is possible to get an almost acceptable picture with adjustments it is just a bit dark.
        • maxvalutech
          • 804
          • australia
          Have decided to give up on this set. Can't see how I can make any measurements with tcon buried as it is and even to get at it is a pull half the set apart job. It is 10 years old. I have reset picture as best I can and will give it away to someone. Adjusted picture pic shown here.
          • maxvalutech
            • 804
            • australia
            Oops pic didn't load so here it is.
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
              09-06-2024, 05:27 AM
            • alltvrepairs
              Lg TCon test pins for screen test
              by alltvrepairs
              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
              Appreciate your help....
              06-13-2025, 06:33 AM
            • sigmeyer
              Toshiba 50UL4B63DG faulty screen?
              by sigmeyer
              I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
              08-30-2025, 08:13 AM
