Help ! Blaupunkt 32/147i
  • smallprint
    • Nov 2010
    • 86
    Hi could anyone shed any light on this blaupunkt 32/147i-gb-5b-hbkup-uk set i have aquired. Basically the guy i got it off had a blackscreen with sound fault and he's read on the internet about a fault with the ic and proceeded to to try and flash the firmware to try and fix it himself and it hasn't worked for obvious reasons being the mainboard had 3 blown caps one bulged and popped (33uf 200v) and 2 leakers at (100uf 63v) which since i have had the set i have replaced and now the screen lights up ok. The problem i have now is the flash he's done has turned the picture upside down and the only .bin i can find which is probably the one he's used is for the wrong model 32/147i-gb-5b-hcdup-uk. The model he had which i now have and i'm trying to resolve is a 32/147i--gb-5b-hbkup-uk and i can't find a firmware file for this model anywhere do any of you guys know where i might find the correct .bin file for it or am i gonna have to replace either the ic chip or whole mainboard ? thanks in advance.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Help ! Blaupunkt 32/147i
    if you cant find a bin file maybe use
    http://www.ohmsupplies.co.uk/E2P180-...M-TPMSD309BP85
    • dskall
      • Oct 2016
      • 2905
      • usa
      Have you tried going into service menu for options
      • smallprint
        • Nov 2010
        • 86
        I've found a board at uktv parts for same sort of dough mate just incase i need to but if i can get hold of the correct firmware then that would be a bonus like.I mean the tv itself only stands me at a fiver so far for the price of the caps i've had to replace it would be shame to have gone to that trouble to have to replace the whole board just because of lousy firmware lol
        • smallprint
          • Nov 2010
          • 86
          It's not the smart tv version dskall you can only update the firmware through usb
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            Just make sure if you buy a secondhand mainboard that it matches the lcd panel number that is used in your tv as if it doesnt you may have the same issue
            • smallprint
              • Nov 2010
              • 86
              Yeah there are 3 or 4 variants of the same board they're also used in technika, logik and bush besides blaupunkt and all are TP.MSD309.BP85 boards.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                did you see this page this is the downloaded file
                Please note i have not unzipped the rar too see whats inside
                https://translate.google.co.uk/trans...cf5875f09adf2d
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  I'm saying options to flip image
                  • HAA
                    • Dec 2018
                    • france
                    Hello All
                    I am looking for Eeprom dump for Blaupunkt TV model: 32/148i-GB-5B-HKUP-EU
                    Any help ?
                    thanks in advance for sharing the file
                    • Obsesion
                      • May 2016
                      • EspaƱa
                      Originally posted by HAA
                      Hello All
                      Any help ?
                      https://mega.nz/#!Lj5SwK5Z!6SaSuYg6-...zhCGoBTE%C2%A0
                      • Daniel Larsson
                        Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                        by Daniel Larsson
                        My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                        I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                        During these seconds the function button is not working...
                        08-13-2025, 10:29 AM
                      • Daniel Larsson
                        Firmware file for Marantz NR1501 needed
                        by Daniel Larsson
                        I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
                        After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
                        The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
                        The content of these seems to be useless as far...
                        05-23-2025, 04:11 AM
                      • GeckoGreen
                        Samsung service bulletin: need firmware file for PN63C550 TV
                        by GeckoGreen
                        I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                        You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                        The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                        Will you please help me get the [2D63]LOGIC.bin file for my TV?
                        05-17-2025, 02:47 PM
                      • ahmedtou
                        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                        by ahmedtou
                        help me please
                        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                        I will share all the details with you, including the disc information.
                        Code:
                        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                        Current Profile: BD-R
                        Disc Information:
                        Status: Empty
                        State of Last Session: Empty
                        Erasable: No
                        Free Sectors: 12,219,392
                        Free Space: 25,025,314,816 bytes
                        Free Time: 2715:27:17 (MM:SS:FF)
                        Next
                        08-27-2025, 08:49 AM
                      • m1ch43lzm
                        by m1ch43lzm
                        Hi everyone
                        09-06-2025, 05:47 PM
