Sony KDL-48R550C, need comments is it Panel FAILURE?
  • jeremykum
    • Feb 2012
    • 95
    • Malaysia
    I hope some experienced tech here can offer some advice.
    Is this TV panel failure?
    Starts up normal, with bright SONY logo. In about 1 second, the logo colour distorted and as can see in the picture, the whole panel have some artifacts and distortion. Then the screen is black without any picture. Have backlight, have sound playing from the HDMI input as long as I don't power off the unit.
    Here I attach 2 photo, which I tried my best to snap it.
    Thanks in advance.
    Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-48R550C, need comments is it Panel FAILURE?
    Did you check the T-CON Bd fuse (F1) to see if you have 5Vdc or 12Vdc on either side also the other T-CON Bd voltages?:
    1. Von/Vgh - (20~30Vdc)
    2. Voff/Vgl - (-5~-8Vdc)
    3.Vdd/Vlogic - (3.3Vdc)
    4. Vda/Avdd - (13~20Vdc)
    • jeremykum
      • Feb 2012
      • 95
      • Malaysia
      Thanks for the assistant.
      TCON F1 fuse both ends have 11.98v (12v)
      One part, HAVDD_8.5V, this pad only have a supply of 8.5V when I was powering up the unit. In an instance, its gone back 0v. Something is not right here. Its directly comes from RT6929 (still trying to search the datasheet)
      Can enlighten me what is this HAVDD ?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Replace the T-CON Bd. One of the ICs and probably associated components gone bad. Easier to replace than repair, yes even less cost to replace than repair.
        • jeremykum
          • Feb 2012
          • 95
          • Malaysia
          Afraid have to locate and replace the IC. Here is the TCON for this model
          • jr.rivera.p
            • Jun 2017
            • 3
            • mexico
            I have exactly the same problem, could you please tell me how you fixed it
            • jeremykum
              • Feb 2012
              • 95
              • Malaysia
              Suspecting RT6269 but cannot confirm at this moment. Didn't manage to locate datasheet and schematic.
              After powering up, the tcon have all power voltage. And lost some of it. Now I also notice the 28v also just available for a second or two, then cut off.
              This is not an easy job, as can't remove tcon from assembly. I don't have equipment to affix the tcon pfc back to the led panel.
              • aljita
                • Nov 2017
                • Estados Unidos
                Hello. Somebody with datasheet? Or solution??
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  On further investigation, I believe that TFTs within the Panel are shorting/defective as a result you are getting voltage drops/loss at those test points. So I will suggest irreparable unless you can access the exact Panel for replacement.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    If I were you A would try disconnecting the ribbon cables from the tcon to the panel then measure output voltages and see if they stay high
                    It's they do try one ribbon cable at a time and see if the voltage is stay high and you have a good picture on 1 side I will be a definitive answer. I would say side tab gate drivers shorting
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4299
                      • Italy - Milan
                      12v on tcon fuse even after problem appears? If yes i would warm up with soldering iron each power section semiconductor starting from power transistors/fets, if you switch on at cold and see immediately defect, then change it.Bye.
                      • jeremykum
                        • Feb 2012
                        • 95
                        • Malaysia
                        Ok, I am back at this TV after months. And found the problem. But it is not easy to replace the faulty chip. A FBGA. This LTF62B0. Going to buy from China about USD2, later I update once I fix and try it.
                        • jeremykum
                          • Feb 2012
                          • 95
                          • Malaysia
                          I don't have equipment to fix the pfc back if I pull it out
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4299
                            • Italy - Milan
                            How do you found the faulty IC?
                            • budwich
                              • Jul 2015
                              • 3097
                              I think you misunderstand... feakaftr8 is referring to the "unclampable cables" not the solder / bonded ones.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4299
                                • Italy - Milan
                                freak is been clear, he don't noticed that jeremy can't unplug tcon output cables..
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Ok i see now. Tcon embedded on the FRC. Oh boy. Did you use heat or freeeze spray to find out that IC was bad?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4299
                                    • Italy - Milan
                                    i have doubts that that big ic is the faulty part, usually central tcon ics have no control on power supply part of the board, so if havdd =half avdd = 17v/2= 8,5v is present only for few instants, probably some part of the pwr supply section is bad or panel is shorted.
                                    • aljita
                                      • Nov 2017
                                      • Estados Unidos
                                      ok, i am back at this tv after months. And found the problem. But it is not easy to replace the faulty chip. A fbga. This ltf62b0. Going to buy from china about usd2, later i update once i fix and try it.
                                      hello. Could you fix? I have two same problem. Plesa coment!
                                        • 12116
                                        • U.S.
                                        Any followup?
                                        • r3vsEngIT
                                          Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
                                          by r3vsEngIT
                                          65x900h with the panel from a 65x930d.
                                          900H: model yr 2020, Samsung panel
                                          930D: model yr 2016, Innolux panel
                                          spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
                                          the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
                                          07-11-2023, 11:11 AM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
                                        • guidodroid
                                          Bad Panel in Sony Bravia X850G
                                          by guidodroid
                                          Hello all,
                                          I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                                          It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                                          Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                                          The issue is not as bad as others that I've seen around, but is indeed noticeable...
                                          03-19-2022, 12:08 PM
                                        • delpiero3
                                          Sony Vaio SVS MBX-261 board failure
                                          by delpiero3
                                          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                                          Nevertheless, let's say, i don't come as a total beginner.
                                          I have this old laptop, which suit perfectly my needs, with the...
                                          10-29-2024, 06:16 AM
                                        • swrb898
                                          Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                          by swrb898
                                          What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                          Problem:
                                          Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                          My troubleshooting got me this far:
                                          With the left-hand TCON to bottom-board ribbon cable...
                                          12-28-2021, 08:12 PM
