weird Samsung Plasma Issue
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Has anyone ever seen anything like this? It goes away on it's own then comes back and stays for extended periods. Going to pick it up today. More specific info to come. Thanks To All.
    LJ
    https://drive.google.com/open?id=0B-...kNRenhfVmNCazQ
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: weird Samsung Plasma Issue
    since there is moving lines on the panel, it might just be a case of cleaning and reseating the corresponding panel cable that goes to the lower buffer (whatever they are called, not y buffer).
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      PN50B450 Sammy
      I noticed that the outer housings of both hdmi connectors on main board are very loose..they actually move quite a bit. Are they supposed to be soldered or screwed down...there are two holes one on each side of the port that look like maybe they were supposed to be screwed down..could this be from poor connection between hdmi cable and port?
      Thank You for taking the time to reply!
      LJ
      • R_J
        • 9624
        The hdmi connectors are only held to the board with the connectors pins and the two heavier pins on either side, once the back cover is on there should be 2 fine thread screws for each connector that prevent it from moving around.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          I resoldered all the hold downs for the hdmi sockets..rock solid now. One of the main ICs on the logic board was sooo hot you could not touch it.
          Replaced the logic board and we are in our 24 hour burn in now..so far so good..a couple hours in no issues..and it's 96 degrees here...so it's really getting a heat test.
          Thanks to all
          LJ
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            12 hours and no more panel disruption..I think the IC on the logic board was the issue..good deal!
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Survived one 12 hour burn in...will do another today.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                sounds like you have a winner there. great stuff.
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Looks like you may be right on the ribbon cable...after two 12 hour burns, Now I get this distortion. It is different from original distortion so the logic board was not in vain. I guess I'll take it back apart further and clean /reseat the lower ribbon cable in the area of the distortion.
                  Aaaarrgh!
                  Thx to all
                  LJ
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    a clean with some iso or a rubbing with an eraser should hopefully fix it up.
                    • ljintexas
                      LJinTexas
                      • Jan 2015
                      • 669
                      Well sports fans..I am afraid this is the chip embedded on the panel ribbon cable. Still comes back to varying degrees after a long burn..say 8 hrs. Then it's fairly often after that. Stripped it down to the panel ribbons and all have heat sink pads that are still good on the cover. I did apply iso to the ribbons in question but they look like they are bonded down to the board. Also cleaned both ends both ribbons from logic board.
                      Thanks to all.
                      LJ
                      • Kjell
                        Samsung Series 9 - BIOS issue
                        by Kjell
                        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                        08-01-2025, 09:15 AM
                        09-07-2024, 05:50 AM
                      • lp20th
                        Samsung Plasma TV Power Supply Issue
                        by lp20th
                        I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                        11-28-2023, 10:28 AM
                      • Cooperr
                        Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                        by Cooperr
                        I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                        The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                        10-21-2025, 01:11 PM
                      • Nairolf
                        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                        by Nairolf
                        I have a Samsung DM32D display.
                        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                        Here’s what I have tried so far:
                        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                        From these tests, I suspect the problem might be on the mainboard. Could anyone...
                        08-24-2025, 03:47 AM
