weird Samsung Plasma Issue
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Has anyone ever seen anything like this? It goes away on it's own then comes back and stays for extended periods. Going to pick it up today. More specific info to come. Thanks To All.
    LJ
    https://drive.google.com/open?id=0B-...kNRenhfVmNCazQ
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: weird Samsung Plasma Issue
    since there is moving lines on the panel, it might just be a case of cleaning and reseating the corresponding panel cable that goes to the lower buffer (whatever they are called, not y buffer).
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      PN50B450 Sammy
      I noticed that the outer housings of both hdmi connectors on main board are very loose..they actually move quite a bit. Are they supposed to be soldered or screwed down...there are two holes one on each side of the port that look like maybe they were supposed to be screwed down..could this be from poor connection between hdmi cable and port?
      Thank You for taking the time to reply!
      LJ
      • R_J
        • 9535
        The hdmi connectors are only held to the board with the connectors pins and the two heavier pins on either side, once the back cover is on there should be 2 fine thread screws for each connector that prevent it from moving around.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          I resoldered all the hold downs for the hdmi sockets..rock solid now. One of the main ICs on the logic board was sooo hot you could not touch it.
          Replaced the logic board and we are in our 24 hour burn in now..so far so good..a couple hours in no issues..and it's 96 degrees here...so it's really getting a heat test.
          Thanks to all
          LJ
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            12 hours and no more panel disruption..I think the IC on the logic board was the issue..good deal!
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Survived one 12 hour burn in...will do another today.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                sounds like you have a winner there. great stuff.
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Looks like you may be right on the ribbon cable...after two 12 hour burns, Now I get this distortion. It is different from original distortion so the logic board was not in vain. I guess I'll take it back apart further and clean /reseat the lower ribbon cable in the area of the distortion.
                  Aaaarrgh!
                  Thx to all
                  LJ
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    a clean with some iso or a rubbing with an eraser should hopefully fix it up.
                    • ljintexas
                      LJinTexas
                      • Jan 2015
                      • 669
                      Well sports fans..I am afraid this is the chip embedded on the panel ribbon cable. Still comes back to varying degrees after a long burn..say 8 hrs. Then it's fairly often after that. Stripped it down to the panel ribbons and all have heat sink pads that are still good on the cover. I did apply iso to the ribbons in question but they look like they are bonded down to the board. Also cleaned both ends both ribbons from logic board.
                      Thanks to all.
                      LJ
                      • Kjell
                        Samsung Series 9 - BIOS issue
                        by Kjell
                        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                        Yesterday, 09:15 AM
                        09-07-2024, 05:50 AM
                      • lp20th
                        Samsung Plasma TV Power Supply Issue
                        by lp20th
                        I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                        11-28-2023, 10:28 AM
                      • vincentedel
                        Samsung SyncMaster 740n Phase Control Issue
                        by vincentedel
                        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                        04-22-2025, 12:33 AM
                      • Manucsl
                        QE65Q800TATXXC Samsung TV Issue
                        by Manucsl
                        Hello.
                        My TV is a QE65Q800TATXXC Samsung TV.
                        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                        Any ideas to check would be very appreciated 😊
                        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                        02-19-2025, 07:47 AM
