Hitachi LE55A6R9 LED Issue or?
  • LITEZONER
    GO BOLTS!
    • Mar 2010
    • 223
    Re: Hitachi LE55A6R9 LED Issue or?
    PS Pretty good pictures right? LOL
    39 Soldering Iron burns And Counting
    • LITEZONER
      GO BOLTS!
      • Mar 2010
      • 223
      1/2 hour in.
        The new set of the LED may have bad solder joints on the connector pins that join the two strip together.
        Glad to see it is working.
        • tjonnyc
          • Aug 2017
          Oh wow, can't believe I found a thread about the same exact model TV, and with a very similar problem... and people who actually seem to know what they're talking about
          My situation: a TV at a friend's house died a week ago. Hitachi LE55A6R9 LCD TV, powers on, switches inputs/sources, and there is an image on the screen if I shine a flashlight onto it. But the LCD backlight is dead, all black.
          I have a digital multimeter, and a soldering iron, and know how to desolder / solder in basic electronic components. But I have no clue which components are responsible for this failure. Also, I'm willing to order replacement parts, but I don't know which parts to order. (I'm not there to keep messing around with additional tests).
          Not really looking to make this a complicated project, just doing a favor for a friend who's on a limited budget and doesn't want to throw out a $ 600 TV.
          So, in a situation like this, where the backlight is totally dead - what should I look for as far as replacement parts? Either an entire board, or solderable components? (I doubt I can replace SMD devices, but standard solder connections shouldn't be a problem).
          Also, if it's a matter of replacing individual components, I'd really appreciate any heads-up about potentially dangerous capacitors...
          Any advice would be much appreciated!
          • dskall
            • Oct 2016
            • 2905
            • usa
            #65
            In a dark room do backlights flash on when first powered on?
              Read post 45 and later.
              • yaya3gmax
                Laptop Power Issue – Works on Battery, Fails on Adapter Load
                by yaya3gmax
                Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                Symptoms:
                • Laptop works normally on a pre-charged battery.
                • Battery does not charge when adapter is connected.
                • Without battery:
                  • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                  • Speakers “pop” when power cut occurs indicating harsh sutdown.
                  • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                08-21-2025, 07:16 AM
              • Robin21
                Ubiquiti US-48-500W – No LAN Port LEDs, Possible 12V Issue?
                by Robin21
                I’ve got a Ubiquiti switch (model US-48-500W, motherboard: USW48P_BCM) on my bench. The switch powers on, but none of the LEDs next to the LAN ports light up.
                I’ve measured voltages across the board and suspect a problem with the 12V rail. At the coils where I’d expect 12V, I’m seeing around 6.3V. One coil shows a stable 6.378V, while the other fluctuates between 6.270V and 6.310V.
                All other voltages seem fine — 1V, 3.3V, and 5V are present and match the expected values.
                I've replaces both buck regulators already (AOZ1212)...
                09-25-2025, 03:24 AM
              • MDY94
                Hitachi 50HK6100U display issue
                by MDY94
                I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
                12-18-2024, 12:31 PM
              • navagator
                Hitachi 57F710E Power Issue
                by navagator
                I have a Hitachi 57F710E Rear Projection TV that was working great until 3 or 4 days ago. I came in and tried to turn it on and it was just dead. So, I unplugged it and plugged it back in. Nothing, not even the slight click that it makes when you plug it in. So, I removed the power supply board (It's a vertically mounted board, I believe model HA01312) and inspected it visually for bulged caps or burnt or overheated components, anything that didn't look right and couldn't find anything.
                I noticed on the bottom of the board there was a row of solder joints with voltages printed next...
                11-09-2023, 06:05 PM
              • AJ847.63e
                Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                by AJ847.63e
                Hi Folks,
                Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                05-06-2025, 10:37 PM
