Samsung PN50B450 sparking screen
  • paulstef
    • Dec 2013
    • 724
    Hi experts,
    I've never seen something like this before. There are sparks inside the screen near the X board. When I remove metal plate under the mainboard that connects chassis to outer metal frame the sparks occure between these two. Nice lightshow.
    There is a black shadow on the upper left corner (slow mow pixelisation effect) similar to the attached pic.
    VS/VA, 15V are ok. No cold solder joints, apparently no faulty component on x-main.
    What should be the signal like on the flatcables towards the screen? What can be measured there?
    Thanks for any ideas
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Samsung PN50B450 sparking screen
    someone else had a similar problem once, but i can't remember on what model.
    he ended up replacing the insulated foam tape that goes on the inside of the outer glass frame and it sorted his problem out.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      https://www.badcaps.net/forum/showth...light=sparking
      • paulstef
        • Dec 2013
        • 724
        It sounds like a very similar problem. I'll check it out.
        I still have the dark left picture though which looks more like a X-Main fault but couldn't find anything wrong with it yet.
        Here we go disassembling a Plasma panel...
        • sordids999
          • May 2013
          • 2152
          Vsc voltages and Ve ok ?
          • paulstef
            • Dec 2013
            • 724
            yes, all checked.
            • paulstef
              • Dec 2013
              • 724
              The panel is toast. There is a conductive grid inside/underneath the glass where the flat cables from X-Main come. This grid is largely interrupted and this is where the sparks fly from one side to the other.
              At least I learned something, e.g. that the inside of the protection glass is conductive Could be used for some project maybe
              You can see it in the video here:
              https://www.youtube.com/watch?v=Zpm_oDCAUFk
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                didn't know that was your youtube account.
                are you sure that you can't insulate it between the arcing points?
                • paulstef
                  • Dec 2013
                  • 724
                  The X-main cables go to the grid, then the grid is interrupted, the other side of the grid not being accessible. There is nothing I can do unfortunately.
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    that sux, at least you found it quickly.
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • Chrissygizmo
                      samsung galaxy ao2s very temperamental after screen replaced
                      by Chrissygizmo
                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                      Ive eventually managed to get it on and working but it's very temperamental...
                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                      05-26-2024, 12:05 AM
                    • Kiberge
                      Samsung LH82QENELGC/EN Help needed - Static line on screen
                      by Kiberge
                      HI guys!
                      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                      04-22-2024, 11:28 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • kotel studios
                      Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                      by kotel studios
                      Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                      In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                      Today, 02:07 AM
