Samsung LN55B650T1FXZA no backlight
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    TV have sound but no backlight.
    I can see image in the dark with a flashlight.
    If disconnect the main board - PSU cable nothing happen.
    LD: 12.35v
    FB1 and FB2: 0v
    Re: Samsung LN55B650T1FXZA no backlight
    1) Did you find out if you have BL-ON signal to turn on the backlights circuit or not?
    2) Do you have about 380~390vdc between the + and - legs of either one of the two main filter caps?
    3) The fuse in the middle of the board which is for the inverter circuit is good?
    4) Did you see the backlights even come on for seconds if you at the screen in the dark room?
    5) the white rectangular cap with 2h684K has the correct capacitance?
    LD Voltage is find, >11V = good, <10V = bad
    FB1 and FB2 are very low AC feedback Voltage, they are not present at this point because the backlights are not on.
    I cannot read the power supply board P/N, it looks like BN44- 00???
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      Inv-On: 5.1v
      Main Caps: 386v
      Fuse: Ok
      Backlight never come
      Cap 2H684K: 9.5nf ?????
      Power Supply model: BN44-00268A
        684K = 0.68uF 10% tolerance
        Did you remove it and measure it off the board?
        • alfredomfr1
          • Oct 2014
          • 318
          • usa
          I measured outside
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            If that reading is correct then it's faulty and you need to replace it. Plenty on Ebay.
              Originally posted by alfredomfr1
              I measured outside
              Well, you found the cause of the problem.
              BTW, do you see any bulging on the sides of that cap?
              • alfredomfr1
                • Oct 2014
                • 318
                • usa
                No bulging on the sides of the capacitor.
                I will order a new one and let you guys know what happen
                Thanks for the help
                • alfredomfr1
                  • Oct 2014
                  • 318
                  • usa
                  Capacitor Replaced: TV working good again
                  Thanks budm and D Barton
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    Thanks for the update glad the capacitor fixed the issue.
                    • jones
                      • Jan 2012
                      • 23
                      same model, same problem, same bad cap 0.684n
                      • jones
                        • Jan 2012
                        • 23
                        video of it https://www.youtube.com/watch?v=ibnj4DMVtGE
                          09-07-2024, 05:50 AM
                        • C152Heavy
                          by C152Heavy
                          Summary for TL-DR readers:
                          • VCC pin (18) of PFC...
                          01-11-2023, 02:53 PM
                        • sansanpartida
                          Samsung QE82Q70RAT no backlight
                          by sansanpartida
                          Hi everyone!
                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                          My issue: No backlight.
                          Model: QE82Q70RAT
                          Type No: QE82Q70RAT
                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                          So hopefully, I can fix this cheaper.
                          05-22-2024, 06:56 AM
                        • howardc64
                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                          by howardc64
                          TV was fixed just after removing Samsung's rear snap cover.
                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                          Maybe PSU->backlight connector didn't have a good contact?...
                          07-23-2025, 12:34 AM
                        • howardc64
                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                          by howardc64
                          • Prior owner tried a replacement main board. No difference.
                          • Samsung 2x red blinking standby LED = panel fault
                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                          07-19-2025, 10:54 PM
