Toshiba 46g300u3 screen turns off after hours
  • BestYohman
    • Feb 2017
    • 29
    Toshiba 46g300u3 screen turns off after about 2.5 hours. The power light stays on and the chrome cast I have remains powered. Sound does not continue also the backlight is off. The TV will turn back on immediately and stay on for another 2.5 hours. When it goes out the screen turns off followed by the sound 3 seconds later.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Toshiba 46g300u3 screen turns off after hours
    Sounds like something is overheating. When it turns off take the rear panel off and direct cool air on the boards to try and identify what may be overheating.
    • BestYohman
      • Feb 2017
      • 29
      My thought was if it was over heating it wouldn't come back until cool. It comes right back on no issues
      • dskall
        • Oct 2016
        • 2905
        • usa
        Do you still have all voltages when it turns off?
        • Ian Paul
          • Mar 2017
          • 23
          • United Kingdom
          Is there some kind of automatic power down setting in menu?
          • vinceroger69
            • Mar 2012
            • 6714
            maybe try a factory reset page 34 in the manual
            • BestYohman
              • Feb 2017
              • 29
              It's not automatically turning off. That setting is off. I'm not at home I'll get voltages then.
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • frannyjunk
                Hisense 40H4F no backlight but turns off after splash screen
                by frannyjunk
                So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                TIA.
                09-24-2025, 10:59 AM
                09-06-2024, 05:27 AM
              • Rav_tangle
                MacBook Pro 2011 turns on with keyboard light , screen dead
                by Rav_tangle
                Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                is this...
                05-31-2024, 04:09 PM
              • sigmeyer
                Toshiba 50UL4B63DG faulty screen?
                by sigmeyer
                I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
                08-30-2025, 08:13 AM
