Sony KDL-40XBR2 intermittent black screen?
  • kgavionics
    • Apr 2017
    • 152
    Hi guys
    I have a Sony KDL-40XBR2 and it's got a weird problem.I fixed a lot of tv,,but it's the first time i face a problem like this.I didn't trouble shoot this tv yet.i want just to know if someone have this problem, so i can fix it quickly.
    the problem some times the the tv doesn't turn on,it has the green light in front and i hear the relay click, they the tv restarts and stays like that with a black screen and green light on.
    to fix the problem, i have to disconnect the tv for few hours ( from 2 to 4 hours minium), then when i plug it back in.it works without any problems.
    i noticed that if the tv shows black screen and i disconnect it from the power then plug it back in, the tv power up automatically, normally i have to press on the power button, but when the tv is working properly if unplug it and plug it back in,the tv stays off till i turn it on either with the remote or the power button.
    i have downloaded the service manual and i don't see a similar problem.so before i take it apart i wanted to know if someone had this problem with this kind of tv.
    thanks in advance
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-40XBR2 intermittent black screen?
    Could you share the Service Manual with us so we could advise better?.....Off the top of my head, I would guess and I say guess, cold solder joints on BGA chip and/or faulty PSU.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Backlights?
      • kgavionics
        • Apr 2017
        • 152
        Sorry guys i can't upload the manual, because its size exceeds 19 Mo.
        • kgavionics
          • Apr 2017
          • 152
          hi
          i just took the tv apart.I checked the voltages they seems alright expect that the stby voltage is zero.
          i think that it might be the problem.
          • dskall
            • Oct 2016
            • 2905
            • usa
            You would have to have standby voltage or you would have no panel light. You would not have your other voltages.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              I would look for cold solder joints on the PS.
              • kgavionics
                • Apr 2017
                • 152
                thanks for the heads up.
                you're right dskall, i made a mistake i have the stby power (5V).
                I have uploaded the schematic for the power supply.I have made the annotations in blue of the voltages that i measured when the tv is not working ( black screen).
                i'm going to check if there's a bad solder join in the power supply.
                  Post #8
                  "I have uploaded the schematic for the power supply.I have made the annotations in blue of the voltages that i measured when the tv is not working ( black screen)."
                  So 18V is not present when TV stops working but the 7V and 11V are still present?
                  7V, 11V, 18V are generated by the same power transformer so if 7V and 11V are still present then you need to check the connection in that 18V section,
                  • kgavionics
                    • Apr 2017
                    • 152
                    guys i have updated the power supply manual with all the voltages.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      No 11v on CN6203. Bad connection. And you checked D6258?
                      • kgavionics
                        • Apr 2017
                        • 152
                        Thank you guys
                        i think i have fixed the problem.I checked for bad solder joint, but all seemed good,so i cleaned the bottom side of the PS with alcohol. I left it for 15 min then plug it back in.Now the tv seems to work without any problem. I've unplugged an plugged it it several times and it works.i'll keep trying just to confirm that the problem has been fixed 100%.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          I think you must have some cracked traces
                            No 7V and no 18 BUT 11V is present per updated PDF then I would resolder all those sections of the power supply.
                            • HTR-Informatique
                              by HTR-Informatique
                              02-09-2025, 06:51 AM
                            • Audeze
                              Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                              by Audeze
                              I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                              Does...
                              10-06-2024, 08:54 PM
                            • AJ847.63e
                              1080ti intermittent black screen
                              by AJ847.63e
                              Hey all I've been asked by one of our neighbours to have a look at a new to him pc he's recently built. He noted when he first built it he couldn't get any video out of the system but it seemed like it was booting into windows as he was able to use the caps lock light and ctrl+alt+delete wouldn't reboot the pc like it should if your stuck in a boot loop. Also the board he has all the post lights would go through their usual cycle and eventually turn off. He swapped the graphics card and still same issue so he asked us to have a look at it.
                              I hooked it up and at first couldn't fault...
                              05-06-2023, 06:32 AM
                            • Ihandyrepair
                              sony 55X850D black screen no front white or red led light.
                              by Ihandyrepair
                              Hi guys
                              strange one
                              I have a dead Sony 55X850D
                              when plug in, black screen, no front white or red LED, no back light no screen
                              Voltages I get
                              3.3v LD/power and main board
                              reg 12V
                              reg 19V
                              3.3v on power on pin
                              no Tcon on
                              no tcon 12v
                              no BL_on
                              I do get BL_ERR 2.0v
                              I tried to bypass it by ground it but still get same symptom
                              I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                              or is possible the chip next to...
                              08-07-2024, 04:58 AM
                            • salvatore22
                              Sony KD-55XE8505 black screen with sound
                              by salvatore22
                              Hello everyone…I hope someone can help me to figure out…i have a sony tv which the screen is black but i can hear the sound …so I try in another similar tv a t-con , motherboard and all works perfect but in this tv i see only a black screen with illumination…the display is not broken ..so I think the problem is on the buffer board …someone can help me? Thanks in advance
                              10-31-2023, 09:30 AM
