1080ti intermittent black screen
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Hey all I've been asked by one of our neighbours to have a look at a new to him pc he's recently built. He noted when he first built it he couldn't get any video out of the system but it seemed like it was booting into windows as he was able to use the caps lock light and ctrl+alt+delete wouldn't reboot the pc like it should if your stuck in a boot loop. Also the board he has all the post lights would go through their usual cycle and eventually turn off. He swapped the graphics card and still same issue so he asked us to have a look at it.
    I hooked it up and at first couldn't fault it. Then all of a sudden it started doing the same thing. Boots, seems like it's in windows but you would never get video from the card. No bios splash screen. Np windows loading splash screen. No windows Lock Screen. Just black, the monitors backlight is on and it picks up a signal but no picture. I removed the graphics card and the pc booted fine several times. I put the GPU back in and again same issue black screen. I then put the GPU in our test system and it worked fine until loading superposition which immediately crashed then windows BSOD.
    I Put the card back in the original system and it ran fine for several days, couldn't get it to fault again. Until last Friday. I was doing some research on this as I had the exact same issue on my watercooled 2080ti except reseating the hdmi cable would resolve the issue so o never looked further into it. I found a few guides and videos mentioning these symptoms and are usually memory corruption, but with those you should see the lights on the card turn off but with this one all the lights stay on permanently. I downloaded and ran mods anyway hoping it would find something but nope all that passed fine.
    So long story short what else could be causing this? Just seems extremely weird how intermittent it is. Especially when the system boots perfectly without the GPU, so you would think it's a faulty GPU but our test system doesn't seem to like it. And we've tried both PCIE slots on the original board so it can't be a damaged PCIE slot either.
    Is it worth trying to update the cards BIOS? It's a asus turbo 1080ti. I'm suspecting that may be the issue as when it was working last after booting into windows and just leaving it on the desktop doing nothing for a good 20 minutes or so the fan would suddenly go to 100% despite temps being low and the card being under zero load and this was the only consistent thing I could get the card to do so I'm thinking the bios maybe partially corrupted.
    Thanks for the assistance.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3630
    • slovakia
    Re: 1080ti intermittent black screen
    your mod run is useless. u must use mods from bundles like Lord of GPU or others
    • AJ847.63e
      • Aug 2020
      • 171
      • Africa
      Thanks I was wondering that, as the one I downloaded was only like 400mb seemed a bit too small. I found a download link on this forum to the kings overkill so I've downloaded that still transferring the files across to the usb.
      I've had a look to try find a bios file for the 1080ti turbo from asus but weren't able to find one, only the higher end cards. Does anyone know of there's other bios file's compatible with the turbo? I know with Ampere and Turing you can mix n match certain ones, my 3080ti hof is using a STRIX 600w modded bios but I haven't had any experience with Pascal.
      Thanks again
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3630
        • slovakia
        not on tech powerup?
        https://www.techpowerup.com/vgabios/...i-11264-170317
        • AJ847.63e
          • Aug 2020
          • 171
          • Africa
          Ha, that's what I get for assuming a websites search function would work. Thanks. I'll give a bios flashback a shot and see how it goes.
          In the meantime, I downloaded and tried MODS from the kings overkill video and same result, passed. If the fault is intermittent that would be expected though wouldn't it? Or does MODS check every memory address? Seems like only a small portion of the memory is faulty as 9/10 reboots it works fine.
          • AJ847.63e
            • Aug 2020
            • 171
            • Africa
            Is there any configuration you need to do in the tiny configuration file so mats runs off of the secondary PCIE slot? I've installed a known good GPU into the primary slot so I can get a picture and moved the 1080ti to the secondary slot and now mods is stalling at "\bin\sh: can't access tty: job access mode turned off" upon bootup.
            • wizard13
              Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
              by wizard13
              I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
              I have checked the forum and the available documentation but could not find a solution specific to my issue.
              • Brand & Model: Dynabook Satellite Pro C50D-B-100
              • Part Number (P/N): PYU13E-00C00PFR
              • Serial Number (S/N): 22028896H
              • System Configuration (SC): A1PYU13E1127
              • Motherboard Model: IP3_ACN16_MB_V21_20211222A
              • Power Input: DC 19V –
              02-28-2025, 02:43 AM
            • HTR-Informatique
              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
              by HTR-Informatique
              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
              I also changed the screen because the PC fell and the screen was broken.
              I changed the battery with a new and original battery.
              I also had corrosion/oxidation on the...
              02-09-2025, 06:51 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • VcemPzd
              Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
              by VcemPzd
              Hello everyone !
              My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
              04-28-2025, 10:14 AM
            • DaniK
              Acer Aspire E5-574-52RH - black screen
              by DaniK
              I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
              Laptop came in for a SSD upgrade, took everything apart to install the SSD.
              Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
              Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
              The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
              Symptoms are:
              - random black screen after displaying Acer logo...
              02-21-2024, 06:27 AM
