Sony KDL-32S3000 LCD 2 Blinks Error code
+ More Options
Posts
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    good call; proper diagnosis!
    Originally posted by budm
    Your TV is WAX3 chassis, not SE1A chassis.
    See training manual about 2-blink code page 22, 30.
    Ah, now that's more like it. The manual I had must've been for the foreign version of this set that used the same model number.
    As for this one, it looks like two blinks indicates a "REG 12V FAILURE" with the possible cause being listed as the power supply board. I guess I'll start there and see if I can track down a replacement.
    Thanks again to you and everybody else who pitch in and help folks out on here. I'd be lost without this forum.
    • SurrealMustard
      • Jan 2015
      • 487
      Replaced power board, no luck
      Unfortunately, the problem somehow still persists even after replacing the power supply board. Any ideas? Did I maybe just get another bad power supply?
        Re: Sony KDL-32S3000 LCD 2 Blinks Error code
        Did you verify that you do have the REG 12V from the power supply board?
        • SurrealMustard
          • Jan 2015
          • 487
          No REG 12V to be found
          I don't see anyplace on the power supply to test for REG 12V, but UNREG 12V is reading next to nothing at all (tenths of a volt at most). REG 24V goes to full voltage when the set is first powered on, but quickly fizzles out and slowly drops to nothing.
            Re: No REG 12V to be found
            Same result with the original and the replacement board?
            • SurrealMustard
              • Jan 2015
              • 487
              #26
              Same voltages with original and replacement boards
              Yes. Exact same .2-.3V on the UNREG 12V and immediate drop-off on the REG 24V using both the original and replacement board. The replacement is used, but allegedly "pulled from a working environment."
                Well, next step will be looking at the service manual for that WAX3 chassis of that model to see how that 12V is generated.
                And just to sure, what is the power supply board P/N for your TV?
                • SurrealMustard
                  • Jan 2015
                  • 487
                  #28
                  Part number
                  The part number on the board is 1-474-052-12.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    shematic
                    • SurrealMustard
                      • Jan 2015
                      • 487
                      #30
                      Analysis of the problem
                      It seems like the 12V should be coming from the power supply though. Given that, I don't understand how we'd be seeing the exact same problem on the replacement. Either something's up on the mainboard or the replacement power supply was afflicted by the same issue as the original. I'll get in contact with the eBay seller to see if we can find out any more information about its origins.
                        Based on the schematic provided, the REG12V is generated by the transformer T6103, D6211,C6252.
                        The primary of T6103 is driven by the secondary winding of the transformer T6101 which generates the 24V, UNREG6V.
                        Transformer T6104 for the UNREG13V uses the same topology, so inspect those parts in the UNREG12V section.
                        You do have 24V, right?
                        • SurrealMustard
                          • Jan 2015
                          • 487
                          #32
                          REG 24V regulated by the power supply?
                          REG 24V would be there for a brief moment upon power on before dropping off into the teens and slowly piddling away.
                          • SurrealMustard
                            • Jan 2015
                            • 487
                            #33
                            Could it be a bad part?
                            Given that, is it possible that I just got another bad power supply?
                            • SurrealMustard
                              • Jan 2015
                              • 487
                              #34
                              Sony: 2 – Me: 0
                              Well, it looks like yet another Sony has escaped my repair efforts. The happy ending is that I was able to get a little bit of cash for it as-is and the seller issued a refund for the (presumably bad) power supply board. Now, it's someone else's problem!
                              • jason123
                                Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                by jason123
                                Hi there,
                                I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                I see 2 posts that are relevant:
                                https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                10-29-2025, 02:01 PM
                              • matwan
                                Sony XR-55X90J 5 blinks
                                by matwan
                                I have problem with SONY 55X90J. After several check status is as below;
                                1. Running power board as stand alone:
                                TCON_12V =~ 12.6V
                                EVDD V On Max 24V= 19V.
                                2.
                                Running power board with TCON as stand alone:
                                Effect as below, attched.
                                3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                Best regards....
                                09-28-2025, 04:26 AM
                              • GoodCapDude
                                Sony XBR-75X940E intermittent 6 blinks error code
                                by GoodCapDude
                                Hi everyone. First post on Badcaps!
                                I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                09-20-2025, 06:07 AM
                              • AK_777
                                Sony KD-65A1 Repair – 4 Red Blinks Error
                                by AK_777
                                Hi everyone!
                                I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                02-20-2025, 04:15 PM
                              • jchon
                                Sony A1e 5-blinks help
                                by jchon
                                Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                I found the service manual, which was critical to know where to probe.
                                https://www.manualslib.com/manual/20...1e-Series.html
                                With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                Unfortunately the 5-blinks...
                                06-28-2023, 11:52 AM
