panasonic tc-p42c2
  • loonytu
    • Feb 2012
    • 10
    • canada
    panasonic tc-p42c2
    i have what looks like burn in really bad but sometimes it goes away for a few seconds then comes back what could be the problem .if I go into menu it looks good but when I exit it u can see the burn in
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: panasonic tc-p42c2
    use burn in white wash if available or run with white noise for one day on full brightness
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Is the main Bd for this TV TNPH0800 2A?...If you are parting this TV for sale I am willing to purchase the Main Bd if the Part No. is TNPH0800 2A. Thanks.
      • loonytu
        • Feb 2012
        • 10
        • canada
        what is white noise I do have scrolling bar in menu
        • loonytu
          • Feb 2012
          • 10
          • canada
          TNPH0831 2A that's my number on main board
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Normal for a pdp tv change cell light to lower.
            • loonytu
              • Feb 2012
              • 10
              • canada
              not sure what u mean
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                My Panny is TC-P42X1...I'm still interested...Thanx.
                Here is the service manual...hope it can help you.
                • BigPete
                  Panasonic Heatpump Dryer Repair
                  by BigPete
                  I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                  The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                  In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                  Unfortunately the whole machine has to come apart to fix it.
                  I have...
                  11-01-2025, 06:40 PM
                • Andre Gilbert
                  by Andre Gilbert
                  11-20-2024, 08:52 PM
                • ttmi100x
                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                  by ttmi100x
                  Greetings everyone,
                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                  Upon closer inspection...
                  07-31-2024, 06:36 PM
                • howardc64
                  Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                  by howardc64
                  Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                  • Backlight on, no image
                  • Disconnect right buffer board (view from front), left side display comes on
                  • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                  • Buffer board is pretty simple
                  Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                  07-11-2025, 04:04 PM
                • AquaMan Ua
                  Problem with PANASONIC CF53 laptop after changing BIOS settings
                  by AquaMan Ua
                  Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                  05-17-2025, 09:40 AM
