Hi guys,
I've got 2 50PJ350 plasma's at the moment both with some sort of power supply fault. The power supply's are part no. EAY60968701 however one is the type with 3 ceramic resistors in the top right, while the other is the model with 2 resistors.
The first of them (3 resistors) has an intermittent problem where sometimes it will turn on fine and other times it will not turn on at all. I've fitted the common repair kit which replaces IC301 and D304 which did not help the issue. I've checked thoroughly for cold solder joints and resoldered all joints on transformers (Had this issue on the same model of TV previously) however all joints appear fine. If it does not start I've been to able to get it to by tapping the board gently with the back of screwdriver making me think that its still a joint somewhere, but any further help narrowing it down would be great.
The second board/TV (2 resistors) does not turn on at all. The power supply simply clicks 3 times, pauses then repeats the clicks and continues on until I disconnect power. Checked for cold solder joints and seems fine also. I've swapped the intermittent board in and it fired right up (still has intermittent issues) so I'm assuming it is in fact a power supply fault. Any help trouble shooting this one would be much appreciated.
Sorry if its a bit confusing please feel free to ask for more details or clarification. I can also add pictures if this would help.
Any help much appreciated.
