LG 50PJ350 Power Supply issues
  • Josh094
    • Jul 2013
    • 17
    Hi guys,
    I've got 2 50PJ350 plasma's at the moment both with some sort of power supply fault. The power supply's are part no. EAY60968701 however one is the type with 3 ceramic resistors in the top right, while the other is the model with 2 resistors.
    The first of them (3 resistors) has an intermittent problem where sometimes it will turn on fine and other times it will not turn on at all. I've fitted the common repair kit which replaces IC301 and D304 which did not help the issue. I've checked thoroughly for cold solder joints and resoldered all joints on transformers (Had this issue on the same model of TV previously) however all joints appear fine. If it does not start I've been to able to get it to by tapping the board gently with the back of screwdriver making me think that its still a joint somewhere, but any further help narrowing it down would be great.
    The second board/TV (2 resistors) does not turn on at all. The power supply simply clicks 3 times, pauses then repeats the clicks and continues on until I disconnect power. Checked for cold solder joints and seems fine also. I've swapped the intermittent board in and it fired right up (still has intermittent issues) so I'm assuming it is in fact a power supply fault. Any help trouble shooting this one would be much appreciated.
    Sorry if its a bit confusing please feel free to ask for more details or clarification. I can also add pictures if this would help.
    Any help much appreciated.
  • sordids999
    • May 2013
    • 2161
    Re: LG 50PJ350 Power Supply issues
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • paulstef
      • Dec 2013
      • 724
      Here a partial schematic I did some time ago:
      http://tomtechtodrepair.blogspot.ca/...c-and-diy.html
      • Josh094
        • Jul 2013
        • 17
        Hi guys, here's the images of the back of the tv and boards.
        • steviewonder
          • Dec 2013
          • 183
          • england
          There's two chains of high-value resistors,connected in series,which forms part of the start-up circuit,you will see these (smd resistors) towards the lower centre of the psu,(rear),simply resolder all of the resistors in the two chains,which should bring some success..
          (I don't have the location numbers currently,as i'm not at home)
          Good luck!
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • unimatrix93
            Identifying backlight resistors, power supply is a BN44-00852
            by unimatrix93
            Dear forum, I would like to ask some help identifying the backlight circuits resistors to limit the ampere to the backlight leds.
            The power supply is a BN44-00852 and I want to decrease the backlight to increase the lifetime of the LEDs.
            The TV is pretty much always on, used for CCTV cameras.
            I suspecting R9838 -> R9841 resistors but I'm not sure. Thanks in advance!
            04-29-2024, 04:49 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
