Sharp LC-43LB371U lines on screen (pic)
  • frequent_traveler
    • Mar 2017
    • 4
    Here's my issue, I have a Sharp LC-43LB371U. I left it on for a few hours and the screensaver came on. I push a button on the remote to "wake" it up and lines appeared on my screen. I tried turning it off, unplugging the tv, taking the back off the TV to look for obvious disconnections or circuit bulges but nothing worked. The lines are superimposed on the screen and the lines will change color and size depending what I'm trying to watch. The top few inches of the screen is perfectly fine.
    Can anyone help me out? I never had an issue like this before and the TV is about a year old.
  • frequent_traveler
    • Mar 2017
    • 4
    Re: Sharp LC-43LB371U lines on screen (pic)
    Sure is difficult watching TV when its in this condition. Can anyone help?
    • heavymachines
      • Mar 2011
      • 1028
      Please read and apply thanks..https://www.badcaps.net/forum/showthread.php?t=39740
      Also read these threads as well..https://www.badcaps.net/forum/search...archid=8467979
      • CapLeaker
        Leaking Member
        • 8119
        We need high resolution pictures of your boards to start with.
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • jeyoung12
          Samsung QN50Q60t lines on screen
          by jeyoung12
          Hi all
          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
          So....i don't know what end of the C ribbon to work with...
          02-26-2024, 10:38 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • EazyBone
          Sharp LC-65Q620U White Screen
          by EazyBone
          Another TV topic!!
          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
          08-21-2024, 12:56 PM
        • kdaniel
          Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
          by kdaniel
          As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
          There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
          After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
          Left...
          11-16-2022, 09:23 AM
