Quick question. Got this TV PSU with the primary mosfet Q5 shorted. Going to change the mosfet and smps ic. The gate resistors and diode have exploded so unable to read their values. What values should be used here for R74 R35 and D6? The mosfet is 6n60 and smps ic l6565.
Polaroid TV - PSU HA220T2A1 repair
Re: Polaroid TV - PSU HA220T2A1 repair
You can use what the application circuit uses.Attached FilesNever stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
No it shouldn't...Try it...you have nothing to loose.Last edited by Andrew F. Ali; 03-14-2017, 04:53 PM.Comment
There seems to be a bit more going on with this PSU. I fired it up with a 100W bulb in series. It lights bright then goes out, but I've got no +5V standby. Main cap is at 330V. Which part of the circuit is responsible for +5V? I find it hard to figure out without a schematic. Nothing else seems to be shorted.Comment
Pin 8 Vcc of IC5 is fluctuating between 10 and 12V so it is not starting up. Have replaced start up cap and zd1 but still fluctuating. Start up resistors, 3 in series at 255K each measure ok. What else could be causing the fluctuating Vcc?Comment
There's a repair kit which may be able to guide you.
http://www.ohmsupplies.co.uk/epages/...roducts/KIT198Willing to help but I'm no expert.Comment
Thanks. Looks like I've replaced or tested everything listed in that kit so far. They don't list the smd resistors and diode I had burned interestingly. Maybe I should replace the start-up resistors anyway even though they are testing ok on the meter.Comment
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM -
by NooyHello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet... -
by redbaron1007I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...1 Photo -
Hey guys,
i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
Now i thought something... -
by MicroSMD LabThe board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the... - Loading...
