Polaroid TV - PSU HA220T2A1 repair
  • tn245
    • Oct 2013
    • 530
    Quick question. Got this TV PSU with the primary mosfet Q5 shorted. Going to change the mosfet and smps ic. The gate resistors and diode have exploded so unable to read their values. What values should be used here for R74 R35 and D6? The mosfet is 6n60 and smps ic l6565.
    Re: Polaroid TV - PSU HA220T2A1 repair
    You can use what the application circuit uses.
    • tn245
      • Oct 2013
      • 530
      Thanks. The configuration here seems slightly different from the application circuit. In that on the board R74 is in series with R35 and D6 which are in parallel with each other. Does that make any difference?
      Application gate drive:
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        No it shouldn't...Try it...you have nothing to loose.
        • tn245
          • Oct 2013
          • 530
          There seems to be a bit more going on with this PSU. I fired it up with a 100W bulb in series. It lights bright then goes out, but I've got no +5V standby. Main cap is at 330V. Which part of the circuit is responsible for +5V? I find it hard to figure out without a schematic. Nothing else seems to be shorted.
          • tn245
            • Oct 2013
            • 530
            Pin 8 Vcc of IC5 is fluctuating between 10 and 12V so it is not starting up. Have replaced start up cap and zd1 but still fluctuating. Start up resistors, 3 in series at 255K each measure ok. What else could be causing the fluctuating Vcc?
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              There's a repair kit which may be able to guide you.
              http://www.ohmsupplies.co.uk/epages/...roducts/KIT198
              • tn245
                • Oct 2013
                • 530
                Thanks. Looks like I've replaced or tested everything listed in that kit so far. They don't list the smd resistors and diode I had burned interestingly. Maybe I should replace the start-up resistors anyway even though they are testing ok on the meter.
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • Nooy
                  VGA MOSfet permanently shorted and loss of MOSfet pad
                  by Nooy
                  Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                  I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                  02-14-2024, 02:26 AM
                • AppleLover123
                  Asus X712EA 3 volts after the first mosfet
                  by AppleLover123
                  Hey guys,
                  i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                  I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                  Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                  I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                  Now i thought something...
                  12-15-2024, 07:49 AM
                • MicroSMD Lab
                  ASUS ROG Zephyrus GPU Mosfet repeat failure
                  by MicroSMD Lab
                  The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                  I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                  01-10-2024, 06:36 AM
                • Scotchmist
                  Asus GA502D keeps blowing mosfet
                  by Scotchmist
                  I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                  I have removed the mosfet and can run the laptop no problem
                  The MOSFET is FDPC5018SG
                  Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                  08-24-2024, 02:23 PM
