Sony DVD player no longer spins
  • pentium
    • Mar 2006
    • 2778
    My Sony DVP-S330 worked perfectly I used it two months ago.
    Then I try to use it today and after putting a disc in I hear noises and then "No Disc". So I open t up and try again and the disc is not even spinning up unless I use my finger to manually spin it less than an eighth of a turn before it spins on its own. I had a Technics CD player that did this years ago but it eventually stopped. Visually the internal PSU looked okay (no burns or bulges) but you never know.
    Is this a caps issue?
    Find Nedry!
    Check the Vending machines!!
  • i4004
    • Oct 2006
    • 2029
    Re: Sony DVD player no longer spins
    it seems laser is dirty or worn(first laser needs to see media in order for motor to spin...i dunno why does motor turn at all(when you help it) if it never recognizes the disc?).
    try cleaning it, and if it doesn't help it's probably junk.
    another option can be that's it's a problem with spindle motos(one driving the cd
    http://books.google.com/books?id=OsX...5VsTgkqZuSNRxQ
    ) and because it doesn't start reading cannot comence.
    come to think of it i should of write this first in this reply.
    you didn't say if you helpi it start restores normal player operation, ie does it play the dics after that.
    if it still doesn't, then it should be optical pickup(laser) problem.
    spindle motor you can try lubricating.
    • pentium
      • Mar 2006
      • 2778
      The laser is completely fine.
      If I flip a disc over and put it in it won't even try to spin up (laser can't see anything) however if it is inserted the right way it "knows" that there is a disc in the drive and will try to spin up and read from it however since it can't spin up it will just say "No Disc" until you eject the tray and close it again, at which point the cycle start over again.
      Also, once I use my finger to manually spin it up it will continue to work fine unless it is stopped again by either reaching the end of the disc or by pressing the stop button.
      Find Nedry!
      • Scenic
        o.O
        • Sep 2007
        • 2642
        Had the same issue on an old Philips CD Player.
        Spindle motor (the one that spins the CD) was a little bit hard-running (like there's a bit honey inside).
        after i put a new motor in it worked fine again..
        however... i was curious and carefully opened up the "stuck" motor...
        the bearings had clogged up with something.. after cleaning and a drop of Ballistol (http://en.wikipedia.org/wiki/Ballistol) it worked fine again..
        • Wizard
          • Mar 2008
          • 2296
          Motor.
          Specifically the motor's commutor segment gaps is filled with crap and shorting it out. It's spun by active control of voltages less than 3V at low current so it is easy to defeat the player's spin up if the motor is worn or dirt commutor segments.
          Fix is replace that DC motor with exact replacement or take it apart and scrape gaps clean, be gentle during the repair and EVEN more gentle on reassembly because of very delicate brushes fingers. It is no carbon brushes, it's alloy spring leafs (3 fingers per brush).
          Cheers, Wizard
          • madmax_2069
            • Nov 2008
            • 27
            i had a dreamcast that had a brush in the spindle motor flipped backwards wile i was playing it, it sounded horrible before it went to a complete stop. i did dive in and fixed it. it looks like it was a manufacturing defect with the brush then it just happening by chance. what it looked like was one of the leads of the brush was broken which cut into the pads on the spindle and eventually caught the brush and flipped it.
            i eventually replaced it with a new motor. but the motor i repaired stil worked but wasn't aligned correctly since i took the motor out of the housing and had issues reading disks that worked fine before.
            • pentium
              • Mar 2006
              • 2778
              Well that is all I need to know Wiziard.
              I'll first look into how much it costs to replace the motor and if that is too much, I'll go at fixing it myself.
              Find Nedry!
              • i4004
                • Oct 2006
                • 2029
                yeah, thank wizard, because that's exactly opposite of what me and scenic said, isn't it?
                it's unfair to thank him alone because he said same thing as we did.
                as for repair, i would first try a drop of wd40: it should clean and lubricate it...
                if it doesn't open it, if yo mess it uo, change it...
                if you like that player so much, that is...
                cost of replacing it? is anybody repairing those anymore anyway?
                any repair will probably cost more than new machine...
                • pentium
                  • Mar 2006
                  • 2778
                  It just seems so strange that it's doing this as when I use my finger to spin it, I don't sense any resistance.
                  Find Nedry!
                  • Wizard
                    • Mar 2008
                    • 2296
                    Correct. Very common symptom. At our work, we usually flick the sluggish/unresponsive spindle motor, if it takes off and at least starts playing. It is motor's commutor gaps filled with conductive dirt.
                    I have fixed few myself where I can't be bothered to replace the motor to get by.
                    Cheers, Wizard
                    • Harvey
                      • Apr 2007
                      • 264
                      As Wizard has said - the symptoms you have are of a worn motor. Its a common occurance on audio CD players, less so on DVD players as its just as cheap these days to use a brushless motor, but it still happens.
                      IF you can't get a replacement (and its about a 95% chance you can't), remove the motor from the PCB and squirt some switch cleaner or similar into the back and spin the motor a few times by hand. That often gets a few more years use out of it.
                      • pentium
                        • Mar 2006
                        • 2778
                        Hmmm, I'll have to see what is in the junk drawer.
                        Find Nedry!
                        • ivtec
                          • Dec 2008
                          • 1967
                          i also have a Sony dvp and it starts to spin and than stops and says no disc i suspect the laser is bad.
                          • ahmedtou
                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                            by ahmedtou
                            help me please
                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                            I will share all the details with you, including the disc information.
                            Code:
                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                            Current Profile: BD-R
                            Disc Information:
                            Status: Empty
                            State of Last Session: Empty
                            Erasable: No
                            Free Sectors: 12,219,392
                            Free Space: 25,025,314,816 bytes
                            Free Time: 2715:27:17 (MM:SS:FF)
                            Next
                            08-27-2025, 08:49 AM
                          • nervous_capybara
                            Repairing the Hitachi DA-6000 CD player
                            by nervous_capybara
                            Hello everyone !
                            I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
                            Feel free to share your experience if you ran into other issues.
                            DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
                            CD tray would not come out of the player
                            I could hear a motor spinning inside the player but the CD tray would not come out.
                            Turned out that the issue was the CD tray belt that aged poorly and began to...
                            11-05-2025, 03:11 AM
                          • bogosort
                            Sony DVD player stuck tray (DVP-SR310P)
                            by bogosort
                            I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                            Anyone knows why?
                            Thank you....
                            05-11-2024, 04:29 PM
                          • Junior††
                            PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                            by Junior††
                            Good Afternoon fellas,
                            Issue:
                            Disc is showing as not supported when a disc is put in.
                            Here's what I've done, you can skip this if you just wanna know the question:
                            - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                            - reflowed the disc drive connector
                            -reflowed the chip in question (shown on image)
                            - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                            Question:
                            I...
                            02-19-2025, 12:48 PM
                          • Carlos#2003%
                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                            by Carlos#2003%
                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                            02-15-2024, 07:52 PM
