samsung CRT security monitor wont power on model ssc-12
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: samsung CRT security monitor wont power on model ssc-12
    one other question what caution should i take in doing anything on this board...i have had it unplugged for 24 hrs...
    • vinceroger69
      • Mar 2012
      • 6714
      i hate working on crts even after a week or longer you can sometimes get a nasty shock search on youtube regarding discharging the crt voltage correctly.
      Edit this may help
      https://www.youtube.com/watch?v=0X28FX_XxtU
      • shelby5041
        • Feb 2009
        • 1505
        im having a real hard time finding any of the components you mentioned....this is a single sided board correct?
        • shelby5041
          • Feb 2009
          • 1505
          right now im not touching anyhting just taking in some info from mr burton but cant find any of the components he is referring to
          • shelby5041
            • Feb 2009
            • 1505
            ok i found u101
            i dont have unassembled so its hard to see and the board is darkened/burned in a lot of places due to heat from components i suppose
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              #26
              I'm not certain that the schematic is an identical match for your board. I can see C501 but not C502 in the diagram
              Best to post pictures to show what they are like.
              For your safety please note carefully what is said in the schematic above on Page 3, Items 14 & 15.
              • shelby5041
                • Feb 2009
                • 1505
                #27
                and i dont have a pc101...i do have a pt101 with 4 legs...black small rectangle shaped..surface mount part
                • shelby5041
                  • Feb 2009
                  • 1505
                  #28
                  on my board c501 and c502 are right next to each other and there is a larger size diode D501 in the middle of both
                  it does seem a lot of reference on the schematics i dont see on my boards...some i do some i dont
                  thats whats making it difficult for me...and i think some of the parts are labeled differently
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #29
                    If you can check that one. I suspect it's the same.
                    It looks like the schematic may be different so what is the full model number of the TV and is there a part number on the power supply board.
                    • shelby5041
                      • Feb 2009
                      • 1505
                      #30
                      i posted some photos before but they are not so good....
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #31
                        the model # of the monitor/system is ssc-12m
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #32
                          i believe your serv manual is for my unit
                          • shelby5041
                            • Feb 2009
                            • 1505
                            #33
                            there are no part# stickers on the board
                            all i see is
                            mm-1245 ver 5R4
                            this looks like a generic multi use board lots of spots with labels but no components there
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #34
                              The linked service manual is for a 12c version and the 12m version so should be correct
                              • shelby5041
                                • Feb 2009
                                • 1505
                                #35
                                and sorry i cant give you a good pic of board there are too many wires and pic tube in the way as is
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  #36
                                  yes i know but it doesnt seem to be 100% accurate as compared to my board
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    #37
                                    and the pt101 looks like 2 legs are on the HV part of board and 2 legs are on the low voltage...there is a dashed line going through the middle underneath....
                                    am i seeing that correct?
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      #38
                                      Posting a picture would help but I believe it is. Two legs on the Cold side and 2 legs on the Hot side
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #39
                                        its hard to post photot since there are wires and pic tube in the way
                                        • shelby5041
                                          • Feb 2009
                                          • 1505
                                          #40
                                          and my camera has no flash....have to use a secondary light which doesnt work well...shadows etc.. here is a photo of pt101
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • mrtek
                                            Samsung UN43NU6950FXZA No power
                                            by mrtek
                                            Hi
                                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                            Main fuse = OK
                                            Back light LED = OK. Power them with aux power source
                                            LED output = OK 156V
                                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                            07-20-2025, 08:06 PM
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
