samsung CRT security monitor wont power on model ssc-12
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i have an old school black and white samsung crt security monitor that will not power on..its a 4 camera monitor with auto switching built in
    it made in 2003
    a couple years ago the display was going real dark on it but would power on fine...and now it wont power on at all..no power light ..nothing...dead...
    not sure if these are both from same issue...but i would like to repair if possible as its a specific onior that i cant buy anymore and be compatible with my cameas
    i dont want tyo install a new system right now...its too much work
    i want to fix if possible...
    thank you
  • shelby5041
    • Feb 2009
    • 1505
    Re: samsung CRT security monitor wont power on model ssc-12
    and there is no clicking sound or any sounds at all when trying to turn on
    on the back is a main power switch in addition to the power switch on front of monitor
    the main glass fuse is ok
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      start with obvious things like power switch .
      just a note the last crt sets i fixed had problems with the H.O.T transistor . if i remember rightly they resided near the fly-back transformer .
      see if you can find a schematic for it .
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        I believe that this is the manual so if you could take some voltage readings.
        • shelby5041
          • Feb 2009
          • 1505
          thank you
          here are some photos..
          • shelby5041
            • Feb 2009
            • 1505
            more pics.....
            • shelby5041
              • Feb 2009
              • 1505
              i am novice
              • shelby5041
                • Feb 2009
                • 1505
                im looking at power schematic and i see the main fuse i see the c101 and i see the sw101 switch they are referring to...i can see them all on my unit...
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  be careful inside this set as very voltages danger ..
                  • shelby5041
                    • Feb 2009
                    • 1505
                    yes....i know...and im very novice...so not sure i will continue...
                    i did test the main switch on back and the actual switch does function using my meter..
                    i have messed with lots of lcd tvs and a few plasma tvs.. over the years and have repaired many...is this crt more dangerous?
                    • shelby5041
                      • Feb 2009
                      • 1505
                      and have worked on the older projection tvs doing convergence repairs...which was a great gig....
                      • shelby5041
                        • Feb 2009
                        • 1505
                        even though the monitor does not power on i am going to check and see if i at least got 12v going to the board for the cameras...
                        • shelby5041
                          • Feb 2009
                          • 1505
                          ok i dont even have 12v going to the camera board....which should have power all the time regardless if monitor display is on or off....
                          • shelby5041
                            • Feb 2009
                            • 1505
                            so this may tell me that its not a monitor power switch issue and is a main power issue..hope someone can heklp me out here
                            • shelby5041
                              • Feb 2009
                              • 1505
                              actually i get 2.5v to the camera board not 0v
                              and i power monitor on and off from the back power switch and voltage does go to 0 when off and about 2.5v when on ...it should be 12v
                              • shelby5041
                                • Feb 2009
                                • 1505
                                sorry for the responses but im just sitting here looking at the boards and thinking out load....i see 2 caps that are slightly bulged but they are away from the power switch they are in middle of board C501 and C502...right next to the large black cylinder looking part that has a single wire coming out of it going into the crt....i doubt these caps could have anything to do with the monitor not powering on?
                                • RukyCon
                                  A Fake Rubycon
                                  • Jan 2017
                                  • 816
                                  It's probably a good idea to replace them as they may cause problems later in life.
                                  The black cylinder part [i think] is the flyback transformer.
                                  I'm not a expert, I'm just doing my best.
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    thank you and yes i understand but right now all i want to do is to get the monitor to power on and get power to the camera board...anyhting else im not worried about at this point
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Page 35 of schematic
                                      It's quite possible that TOP224YC has failed however some initial checks can be done
                                      What DC voltage do you have between the two legs of C103
                                      What DC voltage do you have between pins 1 & 2 of PC101 (PCF801)
                                      What DC voltage do you have between pins 3 & 4 of PC101 (PCF801)
                                      What DC voltage do you have between Pin 2 & 3 of U101 (TOP224Y)
                                      With power off test diodes ZD101, ZD102, D101, D102, D104 using meter in diode mode.
                                      Finally I would remove and measure and if necessary replace C106, C114 & C117
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        thanks a lot mr barton
                                        i will check when i get some time....im very anxious to see if i can this this sytem working again since right now i have no security/video protection at my home.
                                        does c501 or c502 have anything to do with my issue or can i rule them out 100%....as far as the power issue....also do you know what c501 and c502 purpose are?
                                        like i said originally the monitor/system worked great ...for over 12 years it was on 24/7.....i didnt have the display on though..i would only turn that on once in a while ..so not sure why the display went real real dark a couple years ago and then now the system seems to not power on at all...
                                        i believe the front power switch is for turning on display only...with the front switch off...the system still was actually on and the front led lights would be on and switch from camera 1 to cam 2 to camera 3 to cam 4..since this was a switching cam system...and i could have valume up and hear sounds from each cam as they switched......all of this worked with front power switch off if i recall...
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
                                        • Journey11
                                          Samsung TV won't turn on ... keeps cycling the power relay on & off
                                          by Journey11
                                          Hi All,
                                          First time posting here ... my name is Kevin but my friends call me Journey.
                                          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                          07-04-2024, 02:44 PM
