Panasonic TX-P42GT20B - Stuck Stby
  • benjamin.d.bird
    • Jun 2016
    • 45
    • United Kingdom
    Re: Panasonic TX-P42GT20B - Stuck Stby
    Still gives 10 blinks with SC removed
    • tw2005
      • Oct 2011
      • 6458
      Ok ,
      Well we better not jump to any conclusions then.
      Can we get an image of the back or a list of boards? Is there a D board?
      • benjamin.d.bird
        • Jun 2016
        • 45
        • United Kingdom
        Yes it has a D Board - TNPA5299
        • tn245
          • Oct 2013
          • 530
          Watching with interest. I've got the same A board doing 10 blinks even while SC and/or D board disconnected from it. I may follow along on mine with troubleshooting if nobody minds.
          • tw2005
            • Oct 2011
            • 6458
            well I'm getting rusty and lazy. Just spent all day trying to get a damn broken glow plug out of an i30.
            Being a 3D model, it's not one I'm exactly ace on either. 10 blink SC board pops to mind but not if it's doing it isolated. Pretty sure there's a test you can do isolating the A board, TV turns on with either a dim screen or white screen.
            If you can get it to do that Then A board would be high on th elist.
            It's possible to have the “Panel Drive Section” running with the “Signal Processing Section” (A board)
            disconnected.
            By separating the 2 sections, it could be determined if the symptom on the TV is created by the A
            board or one of the boards on the Panel Drive Section.
            Note: Disconnecting D3/A32 and D5/A31 allows the TV to turn on by itself with a white screen after
            it is plugged in to the AC line. This procedure does not disable the A board.
            To completely disable the A board:
            1. Unplug the TV.
            2. Remove connectors P6 and P7 from the power supply. (See note on previous slide.)
            3. Plug in the TV (Do not press the power button).
            • The TV partially turns on by itself.
            • The screen stays black.
            • No fan operation.
            • The LEDs on the SS board and SC board are on.
            To force the TV to display a white screen:
            1. Unplug the TV.
            2. With P6 and P7 disconnected, disconnect D5 from the from the D/A board.
            3. Plug in the TV.
            4. Now the TV turns on by itself with a white screen.
            • tw2005
              • Oct 2011
              • 6458
              Maybe digest this if you have not.
              • benjamin.d.bird
                • Jun 2016
                • 45
                • United Kingdom
                #27
                1. Unplug the TV.
                • No fan operation.
                1. Unplug the TV.
                3. Plug in the TV.
                Tried above steps, no led on SC or SS, with p6 and p7 disconnected, no white screen with p6 p7 and d5 disconnected.
                The only way I can get led on SS to stay lit is to disconnect sc2.
                Does this suggest power board
                • tw2005
                  • Oct 2011
                  • 6458
                  Would suggest SC2 is shorted but why 10 blinks? did you disconnect SC20 ribbon and SC2 power?
                  • benjamin.d.bird
                    • Jun 2016
                    • 45
                    • United Kingdom
                    #29
                    Have not seen led on SC light up at all.
                    • tw2005
                      • Oct 2011
                      • 6458
                      yeah that's great. what do you get for error blink with sc20 and sc2 disconnected.?
                      • benjamin.d.bird
                        • Jun 2016
                        • 45
                        • United Kingdom
                        #31
                        Same can't seem to get off 10 blinks
                        • tw2005
                          • Oct 2011
                          • 6458
                          doing my head in. you may have a double fault, does happen and I have had a bad SC damage the A board to have 10 blinks but the D is in between both.
                          If this was the regular 2D I 'd be more sure. Try that 10 blink steps with the multimeter and let us know.
                          Unfortunately I'll be getting some ZZZZZZs shortly, been a big day.
                          • tn245
                            • Oct 2013
                            • 530
                            In my case I know the P and SC boards are good because I have had them running in another set. Also with D5/A31 disconnected it is turning on with full white screen. As soon as D5/A31 reconnected I get 10 blinks.
                            • benjamin.d.bird
                              • Jun 2016
                              • 45
                              • United Kingdom
                              #34
                              is that with just D5/A31 disconnected?
                              • tn245
                                • Oct 2013
                                • 530
                                Yes, everything else connected as usual, but D5/A31 disconnected I'm getting white screen and leds on sc+ss lit. Odd because I'm sure I was getting the 10 blinks previously with D board disconnected as I stated in my earlier post but this is the state of play now. Possibly at that point I had D board disconnected from P board too.
                                • benjamin.d.bird
                                  • Jun 2016
                                  • 45
                                  • United Kingdom
                                  #36
                                  still giving me 10
                                  • tn245
                                    • Oct 2013
                                    • 530
                                    In this thread 10 blinks on a VT20 turned out to be D board:
                                    https://www.badcaps.net/forum/showthread.php?t=59032
                                    I can confirm that with D board disconnected from P board I get 10 blinks. So assuming your sc board is ok I think D board looks likely, but do check sc carefully because it seems to commonly cause 10 blinks too.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Sounds like it's going to be on the A - board. How close are you guys to each other?
                                      • tn245
                                        • Oct 2013
                                        • 530
                                        Not very, sadly.
                                        So with D5/A31 disconnected I've got my S_15V at the A board and that's when I get white screen and it stays on. With it connected S_15V never comes up. No S_15V must be what is triggering the 10 blinks SOS.
                                        • tn245
                                          • Oct 2013
                                          • 530
                                          I'm going round in circles a bit. 10 blinks is sub5V, sub3.3V, sub9V, F15V, Tuner Power, MIHO 3.3V, LED 8V, FRC 3.3V.
                                          Out of that list the only one I find missing when I get the 10 blinks is MIHO 3.3V. (though it is there when D5/A31 disconnected)
                                          MIHO 3.3V is derived on the A board from S_15V from the P board. S_15V looks to be turned on when the P board gets the Panel_Main_On signal which comes from the D board. The D board seems to send that signal by default when disconnected from A board, but A board (I think) tells D board whether to send this signal via PANEL_STBY_ON through D5/A31.
                                          So it looks like my A board is not giving the signal to the D board to turn the panel on, and is then giving a 10 blink SOS when it doesn't sense MIHO 3.3V.
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • Ancient1
                                            I'm stuck . Panasonic TH-L32U20M panel's boards issue
                                            by Ancient1
                                            Hi
                                            The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
                                            Actions :
                                            1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
                                            1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
                                            Obviously the fault is from or on the Right, secondary board
                                            2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
                                            09-03-2023, 03:51 AM
                                          • stormanimal83
                                            Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                            by stormanimal83
                                            Hey....
                                            Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                            my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                            01-18-2024, 02:15 PM
                                          • gigigi
                                            Panasonic tx-55cx802b stuck on panel test mode
                                            by gigigi
                                            Panasonic tx-55cx802b stuck on panel test mode.
                                            It was working normally but few days ago some of the LED reflectors fall off.
                                            I've opened it up carefully, re-glued, while it was open switched it on to test LEDs.
                                            Then carefully assembled back.
                                            After plugging in to power remote does not work.
                                            Using power button on the TV it turns on but gets itself into a panel testing mode: white, gradient, red, gradient, blue, gradient, green and so on switching between colours.
                                            Anyone knows how to get out of this panel testing mode?
                                            I've tried so...
                                            06-20-2021, 07:06 AM
