Panasonic TH-P65ST60A no STBY light no backlight no power
  • JohnML1975
    • Jul 2025
    • 84
    Hello All
    Started working on this TV today
    As I remove the back will share some photos and findings
    The problem I am having is in the title of this thread
    I still need to proceed my trouble shooting
    Started a thread so that I can share with all
    Any inputs are welcome
  • JohnML1975
    • Jul 2025
    • 84
    Here are photos
    There are no burn marks that I can see
    The two fuses on the power board are serviceable
    I need to check power on the PSU next
    • JohnML1975
      • Jul 2025
      • 84
      Have 347 V at the main filter capacitors which have 450 V written on them
      There is no power to the sustain boards even if I disconnect them
      I am going to check power to the mainbaord next and leave the sustain boards disconnected
      • JohnML1975
        • Jul 2025
        • 84
        Checked power from mainboard to PSU
        there is zero voltage on all 14 pins
        I used thermal camera on the PSU and could not see anything standing out
        removed PSU and cleaned the dust off
        looked around both sides of the PSU board
        there are many cracked solder legs on the MOSFETS and transformer legs
        these appear to be on the mainboard supply and the sustain board supply
        so i am going to resolder every joint, except the SMD joints on the PSU
        then shall refit and test
        • JohnML1975
          • Jul 2025
          • 84
          Soldered the suspicious joints and soldered some others that did not look very good
          refitted the PSU board
          tried to turn on but the failure mode is the same
          no power outout
          going to remove the PSU again and check components with multimeter
          • ivtv1
            • Oct 2016
            • 14
            Have you measured all the outlets for leaks with a multimeter?
            • JohnML1975
              • Jul 2025
              • 84
              Hello and thank you ivtv1
              I am not too sure what you mean
              if you could clarify it would be appreciated
              The PSU does not produce any power to the mainboard
              the PSU does not produce any power to the two sustain boards
              So I think there is a problem with the PSU
              I completed checking the MOSFETS and the diodes which are through hole components
              These are all serviceable
              At the moment I am moving on to check the resistors
              • ivtv1
                • Oct 2016
                • 14
                If there is a short circuit in any of the outputs of the power supply, it will not start. With a multimeter, check for a short circuit to ground.
                • JohnML1975
                  • Jul 2025
                  • 84
                  Thank you ivtv1
                  Today I placed red probe of multimeter on each of the two sustain plugs
                  I placed the black probe on ground
                  There was no shart circuit on the power side
                  next i powered up the board
                  connected to the two filter capacitors are two resistors
                  there is 340 V to one side of the 2.2 ohm resistor
                  there is no power on the other side of the 2.2 ohm resistor
                  when i check OHMS across the resistor there is OL showing on the multimeter
                  the resistor looks okay
                  i will remove it from the board and test it
                  • JohnML1975
                    • Jul 2025
                    • 84
                    This is the 2.2 OHM resistor removed and tested
                    It says OL
                    In the board it measures at around 60 kilo ohms
                    So i think it needs a new resistor
                    • JohnML1975
                      • Jul 2025
                      • 84
                      I fitted new resistor and the resistor just blows up; there is flash and the resistor becomes open circuit again
                      so i guess whatever that resistor is connected to is faulty
                      i shall need to trace that circuit
                      • JohnML1975
                        • Jul 2025
                        • 84
                        I found a shorted MOSFET on the hot side of the board
                        I will need to remove it and test it
                        • lotas
                          • Jan 2016
                          • 4969
                          • Russia
                          This should have been done from the very beginning, after the burnt-out resistor was discovered (resistors don't just burn out), and installing a new resistor could now damage even more components.
                          • JohnML1975
                            • Jul 2025
                            • 84
                            Hello lotas
                            thank you
                            I should have treated the 2.2 ohm resistor the same way i would treat a fuse
                            next time, i will do that
                            meantime, i have found the shorted part and shared a photo
                            each leg is shorted to the other leg
                            the voltage drop is less than 0.03 volt when the DMM is in diode mode
                            when i check the board the short is now gone
                            i am going to order the new part
                            • JohnML1975
                              • Jul 2025
                              • 84
                              I just fitted new part
                              Now the resistor does not blow or go open circuit anymore
                              However, the TV will still not power on
                              There seems to be no power going to the cold side of the PSU
                              Need to trace further
                              • JohnML1975
                                • Jul 2025
                                • 84
                                It looks like IC200 is the problem
                                When I use voltage injection this IC goes to 99 deg cel and becomes hot to touch
                                It is linked to the components which had failed
                                There are no markings on the IC to help me identify and order a new IC
                                I think I have to give up on this TV and discard it
                                • lotas
                                  • Jan 2016
                                  • 4969
                                  • Russia
                                  IC200 - NCP1234AD65R2G
                                  • JohnML1975
                                    • Jul 2025
                                    • 84
                                    Hello lotas
                                    thank you very very very much
                                    I shall buy the new part
                                    will share results here
                                    • lotas
                                      • Jan 2016
                                      • 4969
                                      • Russia
                                      Check all the wiring around IC200 (resistors, diodes, zener diodes...).
                                      • JohnML1975
                                        • Jul 2025
                                        • 84
                                        New part arrived and I am going to fit the new part. Will share the outcome
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • lapfix
                                          HP OMEN NO power no light
                                          by lapfix
                                          HP OMEN : DAG35DMBAD0
                                          NO power ,no short ,no corrusion
                                          Consumption : when charger plg in = 0.004 amp
                                          Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                          when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                          No light at power button led
                                          All coils resistances :
                                          Pl 2001 =3v measured with kohm.
                                          pl 2004 = 5v measured with kohm
                                          pl 6001 = 49.7ohm
                                          pl 4012 = vccsa = 24.4 ohm
                                          pl 3001 =...
                                          11-03-2025, 07:48 AM
                                        • hikomalek
                                          TV LG39LN575S, no backlight power, EAX64905301(2.2), MAP3202
                                          by hikomalek
                                          I would be really grateful for your suggestion how to repair a no backlight power on TV LG39LN575S. There is a visible menu on a screen when I use external torch (so logic board and panel works correctly), there is just no backlight.
                                          I have connected a logic board which is turning on power board and disconnected LED backlight cable.
                                          Power board:
                                          REV2.0 2013.03.28
                                          PCB: EAX64905301(2.2)
                                          LGIT PCB P/N: 3PCR00184A
                                          IC LED driver MAP3202
                                          MAP3202 voltages:
                                          (1) EN = 2.75V
                                          (2) VCC = 12.05V
                                          (3) GATE = 0 V...
                                          07-25-2024, 10:30 AM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
