LG 37LD450 Doesn't Turn On
  • Paul678
    • Nov 2011
    • 402
    The red standby LED turns on solid when I plug the unit
    in, but when I hit the power button, the LED slowly
    gets dimmer, and then slowly gets brighter, and then
    repeats this undulation.
    I cannot turn the undulation off with the power button: I
    must unplug the unit and plug it back in, to get the solid
    red LED again. Nothing shows up on the screen at any
    time.
    All voltages on the power supply seem normal: 3.5V, 12V,
    and 20V. But I don't know of a way to check if the high
    voltage going to the CCFLs is turning on or not.
    I was thinking this is likely a main motherboard issue, but
    it seems possible the high voltage going to the CCFLs
    is the problem.
    What do you all think?
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 37LD450 Doesn't Turn On
    Jumping the backlights on would answer your questions.
    Uploading pictures of the boards would help.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Bga issue on mainboard.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Pson, blon voltages, image on screen with flashlight, flash on screen from backlights, pictures?
        • Paul678
          • Nov 2011
          • 402
          After pressing the power button:
          Power-On=3.2V
          INV On/Off= 0 V
          I could not see an image on the screen while using a strong flashlight
          on it.
          I also noticed a scratch about 1/2 inch right in the middle of the screen....so maybe this one isn't a good candidate to revive anyways!
          • dskall
            • Oct 2016
            • 2905
            • usa
            I would say mainboard, maybe eeprom
            • Paul678
              • Nov 2011
              • 402
              Here are some pics:
              https://www.flickr.com/photos/132723...h/33141927281/
              • Hamie
                • Apr 2014
                • 1383
                As reecy pointed out already.
                Looks like the set uses an XD engine bga. Prone to cracking. Try reflowing it.
                • Paul678
                  • Nov 2011
                  • 402
                  I haven't tried that in years.....link to help refresh my memory
                  of how to do that again?
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Lots of youtube videos.
                    • Paul678
                      • Nov 2011
                      • 402
                      Ok, here's one:
                      http://hackaday.com/2011/02/24/heat-...-fixes-laptop/
                      Should i remove the heatsink first?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Yes. I find it easier to remove them by twisting, rather than pulling straight up.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Remove heatsink, reflow if it works, give it a good reflow and then reapply heatsink with thermal silicon and maybe even add a fan. This is one of these shite Lgs that the cpu heatsink covers half the bloody chip !!!
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Your hackaday link doesn't detail it, but add some flux around the chip before you reflow.
                            • pajdek
                              Lenovo Y700-17ISK turn on and off
                              by pajdek
                              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                              09-20-2023, 02:49 AM
                            • RdeveLabs
                              MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                              by RdeveLabs
                              To all the members here...
                              Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                              So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                              05-05-2025, 04:59 AM
                            • robante15
                              Acer Aspire 4520 won't turn on after reboot
                              by robante15
                              Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                              It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                              The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                              If I remove the...
                              04-06-2024, 06:50 PM
                            • Ledgurra
                              MacBook Pro A1425 it doesn't turn on
                              by Ledgurra
                              hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                              thank you all
                              11-09-2025, 06:07 AM
                            • AlexVaq
                              Samsung UN55HU6840 Solid red light, won't turn on
                              by AlexVaq
                              Hi guys, I hope you can help me out with your experience.
                              I have this wonderful Samsung 4K TV that shows a solid red light when connected to power (standby, I guess), but refuses to turn on. When I press the physical button to turn the TV on (on the back), it does nothing. So I opened it and try some tests. So far I have checked:
                              - That the button works properly.
                              - That the backlight turns on if I disconnect the main board from the power supply.
                              - That the power supply board (a BN44-00755A) gives the right output without load on the CNm803 connector...
                              12-19-2020, 04:10 PM
