Blaupunkt 32/146i-GB-5B-HKUP-UK - Eeprom dump needed
  • Andrzejj
    • Dec 2016
    • 8
    Hi
    I'm looking for an eeprom dump for this TV:
    Chassis: TP.MSD309.BP85
    Model: B32U146THD
    Product code: BA32K146BHKPG015
    Label on LED screen:
    Model: 32LTD
    LVW320SSDX
    Label on motherboard:
    LSC320AN02-A
    If you have the bios bin file please let me know. Thanks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Blaupunkt 32/146i-GB-5B-HKUP-UK - Eeprom dump needed
    Try freezing SPI flash for a good while with compressed air then trying the Tv if it boots download the firmware off umc site and autoupdate it via usb and it should work. Ive gotten away with that a few times.
    • Andrzejj
      • Dec 2016
      • 8
      ReeceyBurger123, I didn't try your solution because I found original eeprom for this TV.
      If someone need it, please download below
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Hello Andrzejj
        I've added it to the EEPROM Dump sticky.
        Many thanks
        • mesta83
          • Nov 2015
          • 75
          • merseyside
          thanks it work
          • HAA
            • Dec 2018
            • france
            Hello All
            I am looking for Eeprom dump for Blaupunkt TV model: 32/148i-GB-5B-HKUP-EU
            Any help ?
            thanks in advance for sharing the file
            • CommanderZod
              • May 2019
              • 3
              • United Kingdom
              How do you get this on to the EEPROM? USB Firmware update says 'file not found' on the TV menu ..
              • diif
                • Feb 2014
                • 6978
                • England
                You'll need to remove the eeprom and program it off the board. The cheapest is a CH341A.
                • CommanderZod
                  • May 2019
                  • 3
                  • United Kingdom
                  Thanks for the info. Do you think the SOIC8 clamp that comes with most kits would work on this without removing the IC ?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Not with any certainty. There are usually caps and resistors that interfere.
                    Always best to remove it from the board.
                    • CommanderZod
                      • May 2019
                      • 3
                      • United Kingdom
                      Hmm I'm not confident removing it. I'm also not 100% certain it's the EEPROM, the unit powers on (red standby LED to blue) but no screen or sound for 3mins 15 secs, after that it's fine until it's power off or put in standby again.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        It's easier to hot air rather than an iron to remove them.
                        It does sound like an eeprom issue to me. They control the turn on functions.
                        • kubbecc
                          • Dec 2021
                          • 14
                          • Slovensko
                          bin file somewhere please
                          Blaunpunkt 32/188I-gb-5b-fhbku-eu
                          B32K188TCFHD
                          BA32D188BFBKUE552
                          T.MSD309.B81U 12176
                          • lotas
                            • Jan 2016
                            • 4593
                            • Russia
                            B32K188TCFHD
                            BA32D188BFBKUE552
                            T.MSD309.B81U 12176
                            Post your non-working dump here, I'll try to fix it.
                            • kubbecc
                              • Dec 2021
                              • 14
                              • Slovensko
                              I will try it tomorrow
                              • lotas
                                • Jan 2016
                                • 4593
                                • Russia
                                Ok
                                • kubbecc
                                  • Dec 2021
                                  • 14
                                  • Slovensko
                                  I'm an amateur, I hope I did it right
                                  • kubbecc
                                    • Dec 2021
                                    • 14
                                    • Slovensko
                                    https://ulozto.sk/tamhle/iTyVlGgXB2z...M5BF5GDzHlZN==
                                    • kubbecc
                                      • Dec 2021
                                      • 14
                                      • Slovensko
                                      Originally posted by lotas
                                      Ok
                                      • lotas
                                        • Jan 2016
                                        • 4593
                                        • Russia
                                        I understood everything, downloaded, I'll try to restore.
                                        • AlexGsmMaster
                                          Eizo CS2740 eeprom dump, search.
                                          by AlexGsmMaster
                                          Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                          07-26-2025, 03:24 PM
                                        • re-atari
                                          Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                          by re-atari
                                          Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                          Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                          02-03-2025, 06:49 PM
                                        • erkko13
                                          Thinkpad L390 Yoga (type 20NT serial R90VZWLN) BIOS2 dump needed
                                          by erkko13
                                          Ho ho ho, badcaps people,
                                          if this qualifies as bios request, hopefully. Actually BIOS2 for that laptop is second smaller SPI flash (Winbond W25Q80DVSNIG-GP-U), containing supposedly some config for TPS65988 which in turn manages USB-C stuff, including PD. This is possibly flash, where update "Power Delivery Firmware (TI TPS65988)" F407.06.29 -- https://download.lenovo.com/pccbbs/mobiles/r10pd10w.exe does its thing. Previous owner claims that after clean install of Windows 10 he installed thinkvantage tool of sort, which updated everything for that laptop. I did glance over...
                                          12-25-2024, 06:41 AM
                                        • (0)_(0)
                                          Looking for a HP Photosmart C4280 EEPROM dump
                                          by (0)_(0)
                                          Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                          The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                          02-17-2022, 09:09 PM
                                        • my2k2
                                          Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                          by my2k2
                                          Good day to every one,
                                          I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                          Does anybody have an eeprom dump file? I really appreciate any help.
                                          Thanks in advance.
                                          07-01-2024, 09:04 PM
