Samsung un46eh5000 bad panel?
  • microvibe
    • Mar 2013
    • 275
    • canada
    Have un46eh5000. Not sure if main board tcon or just complete panel failure . Any ideas.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4463
    • Italy - Milan
    Re: Samsung un46eh5000 bad panel?
    Wow, what a crap! Seems some liquid entered the screen, 90% bad panel sorry... If you're lucky some repairable corrosion on the panel's board, but huge of work to do..
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Check the state of the panel tabs and see if they are damaged.
      • CapLeaker
        Leaking Member
        • 8327
        Get's my vote.
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
          09-07-2024, 05:50 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
