SHARP LC-60E79U display goes from washed out very grainy to white
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    i have had this tv for a while ....am finally getting to trying to repair
    when powered on the tv powers on fine but the display is totally washed out...and you can barely see the image and then the screen eventually goes to almost all white
    any ideas?
    i have been told it could be the lcd screen boards shorting on metal frame but when i look it seems its not touching frame at all
    fyi i replaced with a used tcon board but did not change anything but board was used so no guarantees it was a good board
    and there is power going to tcon board i tested it a while back
    before i toss out tv i want to make sure its not a bad lcd panel.....if it is bad lcd panel of course tv is worthless and would toss out
    see photos
    any help would be appreciated
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: SHARP LC-60E79U display goes from washed out very grainy to white
    T-con made no difference? Does unplugging one ribbon cable at a time make a difference?
    • shelby5041
      • Feb 2009
      • 1505
      hi it has been over a year when i last messed with the tv and now i have time to maybe fix it
      what would removing cables from tcon show?
      what should i look for ?
      like
      if it does this then its this
      or if it does this then its this
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        It would tell you if the panel is bad or not. However, from the pics it looks like bad panel. Make absolute certain you reseat the cables properly and they aren't twisted/crooked or anything.
        • shelby5041
          • Feb 2009
          • 1505
          hi i removed the left side cable
          and here is the pic
          the tv is upside down in the photo so the right side of the pic is the left side cable i removed
          all i want to do is see if the panel is bad....if panel is bad then i will obviously toss tv
          but i have seen people say that the panel boards short out against metal and that can cause the symptoms i have
          tjhe side of screen i left plugged in starts pure black and then gets this funky colorization but the colorization fills more and more of that side of screen as tv warms up and the side of the screen i removed cable starts off white with a few random thin vertical lines and then after a few seconds goes to all white
          i do appreciate all and any advice
          thank you
          • shelby5041
            • Feb 2009
            • 1505
            could it be the main board? Tcon? power supply?
            can i test to rule these out?
            • shelby5041
              • Feb 2009
              • 1505
              and one other thing i noticed....the main board and power supply have a very high resale value on ebay each goes for about $100.00 us...which nowadays is pretty high....this could tell me that these boards fail a lot....and thats why higher priced
              • budwich
                • Jul 2015
                • 3097
                what happens when you do your "cable disconnect" test on the other side?
                • shelby5041
                  • Feb 2009
                  • 1505
                  i will disconnect cable on right side right now and let u know
                  • shelby5041
                    • Feb 2009
                    • 1505
                    ok if i connect left side cable and disconnect right side cable
                    the left side is black but then after a few min it starts doing the weird colorization like other side did
                    and the right side is all white...with a few very faint vertical patterns but they go away after a minutes to pure white
                    pretty much mirrors what i did earlier
                    • shelby5041
                      • Feb 2009
                      • 1505
                      actually after even more time the left side goes all black....after some brief weird colorization that it does...reddish
                      and if i hit osd...nothing appears on left side of screen nor did it on the right side when i had right side plugged in....
                      when i had both cables connected i would faintly see images and osd....but eventually they disappeared
                      • shelby5041
                        • Feb 2009
                        • 1505
                        and if i remove both cables the screen is not black black but actually just dark and you can see that the backlights are on but screen is dark.....
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4326
                          • Italy - Milan
                          The thing about the board touching metal can be that like many the band boards on top of the screen (on the profile's face) with the time can dilate, make a curve and touch on the bezel metal frame, so you have to dismantle that frame to see that and aventually loose the screws that firm that board to plastic chassis.
                          "high resale value on ebay ... ....this could tell me that these boards fail a lot..."
                          this can tell you also only that boards are not so widely available..
                          • budwich
                            • Jul 2015
                            • 3097
                            doesn't sound good. these set will normally produce a white screen for the side that is unplugged. It should be relatively stable. you should probably feed in a known signal (test pattern or equivalent). if you look along the bottom, there should be some little edge boards running along the bottom. These will be connected to the tcon AND also to other panel via bonded tabs / drivers. The boards (maybe two per half of the panel) are connected with "clampable flex cables". Try disconnect one of those clamped cables ... this will isolate the corresponding side along with some of the bottom. The picture may correct depending on the possible failure.... go from there.
                            • shelby5041
                              • Feb 2009
                              • 1505
                              budwich
                              it does produce a white screen on the side that cable is unplugged
                              obviously when both are unplugged the lcd panel would have zero power to it and have the natural darkish lcd panel color...with backlights kind of showing through like ambient..correct?
                              the pure white can only be produced if the lcd panel is getting some type of power
                              or am i wrong
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4326
                                • Italy - Milan
                                An lcd screen unpowered shows only white (all pixels off).
                                For the type of defect it seems to me a panel power supply problem, for example the lack of pixel's source or drain signal, you'll never discover nothing if you doesn't dismantle the bezel.. have you done it? Since the substitute tcon is used, you have also to test power supply test points, like AVDD, VGH, VGL, VCOM, V3D3, V1D8, VGMA's or similar names.. Has to be checked with and without flat cables connected..
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  +1
                                  I agree. It's time to get the meter out and do some testing which could lead to a diagnosis. And some photo's of your circuit boards.
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    The panel is bad.....Part out and sell the Main Bd and PSU while you can still make a little money.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      Originally posted by shelby5041
                                      budwich
                                      or am i wrong
                                      let's back up a bit...
                                      you said
                                      "and the right side is all white...with a few very faint vertical patterns but they go away after a minutes to pure white"
                                      I said a disconnected panel (implied side) would show a STABLE white. How are "very faint vertical patterns" a "stable white". I don't think they are the same. Is it a problem? Potentially. Does it show EXACTLY the same with the cabling "reversed" (ie. the other side unplugged, and the previously unplugged side plugged back in)? Yes, if both tcons cables are unplugged at the same time, the screen will not go white as there will be no power to the panel.
                                      The purpose of unplugging cables is to detect whether there is a possibility of a bad panel as doing a lot of voltage measuring won't really tell you much about a bad panel. The measuring will give you some understanding about the supporting circuitry but it is not without hazard.... hence, trying to do some "high level checks" is usually good especially with sharp panels which seem to have some issues around the tab drivers.
                                      Anyways, I wouldn't give up just yet on the panel even if it is a bad panel as you will find a few threads where people have saved the 60" sharp by removing the bad tabs.
                                      However, it does potentially appear to be a bad panel as some have suggested. Its whether you can determine what is bad about the panel... and whether it can be saved therein.
                                      Still further, as suggested, if the bottom edge boards / tabs have been "wetted" or otherwise, then these will corrupted the display in various manners... have you checked these?
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Something is loading down the panel if it is the panel itself. Low voltage driven to the panel's power from the t-con board could be a problem. We are left here with only thinking that it could be a t-con board in a can be a panel problem. Since you have already replaced the t con board with no change I'm only implied to think the panel is bad
                                        Of course I'm only speaking on the basis that this design with its implied voltage controlling all the driver Ic's connected to the panel may act similar to a plasma receiving low voltage where the whites get washed out and a lot of pink and blue mal discharge.
                                        The problem with this is it looks sort of like a gamma processing problem however it's hard to tell because the black levels are tinged with green and pink. I wonder if there is some secondary control of gamma located on the FRP boards connected in the panel
                                        • thesharpfella
                                          Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                          by thesharpfella
                                          Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                          07-23-2024, 10:37 AM
                                        • Anzio
                                          Sharp LC60E79u 2 blinks power/3 Blinks OPC
                                          by Anzio
                                          I have a Sharp LC-60E79U with the blinking light error (Power and OPC blink 2 times together then OPC blinks 1 time. I read the previous thread on Sharp lc60e79u (https://www.badcaps.net/forum/showth...t=66913&page=3) with this same issue, but no resolution was posted.
                                          The service manual indicates this as a “DET_5V (33pin) error (L). 5V is not applied.”
                                          I cannot enter service mode by pressing input and channel down and plugging the unit in to power outlet. However, I can override and enter the diagnostic mode if press channel down and volume up and...
                                          07-03-2020, 01:12 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • gavenb
                                          Sharp LC-80LE661U 80 inch
                                          by gavenb
                                          Hi folks!
                                          I have a LC-80LE661U that had some interesting issues.
                                          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                          11-12-2023, 02:05 PM
