Phillips LCD Model #42PFL7422D/37
  • Tayninh55
    • Sep 2011
    • 153
    Re: Phillips LCD Model #42PFL7422D/37
    They are both really hard to read, the resister and the capacitor. The resistor has the letter (or letters) RJ, or BJ, or could be just a large R, with the number 750 printed on it. Even with a magnifying glass it's hard to make out the letters. The number 750 was larger and very clear.
    The capacitor was also hard to read. It looks like: 47 Ohm M 275V~X2 and then under that line it has: 3382MKP50709
    No, I don't think I can read capacitance, just have a small multimeter that I purchased at Sears.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Resistor is 470ohm so will have to check it on 2kohm setting
      • Tayninh55
        • Sep 2011
        • 153
        Maybe the resistor is ok then,,,,,,,,,,on the 2000k scale it shows continuity (000 on meter), the same as when you touch probes together. When I checked the resistor on the 2000 Scale,,,it read 469.
          The resistor is OK.
          You will need to check the DCV at the main power supply connectors next to see what you have and also the 25V HOT Voltage.
          • Tayninh55
            • Sep 2011
            • 153
            OK,,,,,,,,,,I'll see what I can find out on the voltages. If you hear a BIG BANG, you'll know what happened! May be a while,,,,,,I've got some other "irons in the fire" as well. Take care!
            • Sly_Boogy
              • Aug 2017
              • 4
              Hello everyone, I purchased a broken TV of this model over the summer in hopes of fixing it, and I have the exact same problem! Same symptoms, same green led lights, clicking, everything. Btw, I didn't see anyone mention this in the thread, but the clicking sound mentioned is when the main board restarts the whole TV.
              *Just as a disclaimer, I am inexperienced repairing electronics, and to be honest, electricity confuses me a bit; so bear with me as I might not use all the proper terminology and whatnot. You may also cringe while reading this.*
              I have been searching through the repair guide which I linked here from my Google Drive (sorry, max attachment size was 19MB, guide was 23MB) and I found an interesting section under fault finding on page 34:
              • Symptom: +1V2, +1V4, +1V8, +2V5 or +3V3 shows a high
              level of ripple voltage (audible noise can come from the
              filtering coils 5U01, 5U02 or 5U60). Possible cause:
              instability of the frequency and/or duty cycle of a dc-dc
              converter or stabilizer.
              1. Check the resistor 3U32 and 3U7D, capacitors 2U17
              and 2U19, input and output decoupling capacitors.
              2. Check a.c. feedback circuits
              (2U23+2U24+3U55+3U63 for +1V2,
              2U6D+2U6E+2U6G+3U6A+3U7E for +1V4 and
              2U07+2U08+3U17+3U24 for +3V3), compensation
              capacitors 2U25, 2U34, 2U36, 2U37, 2U40, 2U43,
              2U68 and 2U6B.
              This is interesting because ever since I got the TV, I have noticed audible noise coming from somewhere on the main board. Its a high pitched electronic squeal, I can record it if you'd like to hear it. Now, I do not know what ripple voltage is or how to measure it, but I do know how to test resistors and capacitors.
              I first tested resistor 3U32, which is a SMD on the back of the main board. It tested ok (38.7k ohms, rated for 39k), but it looks a little funky. I have attached a picture of 3U32. (sorry I couldn't get a closer shot, if I can find my dang macro lens I'll take a better one.) It has continuity to the next components, but it almost looks burned or unseated, at least compared to the others. For some reason I then plugged in the board, and I touched a probe to the resistor. The squeal immediately became much more intense, as if I had touched an open wound. The board restarted if I recall correctly.
              I also noticed that there seemed to be heat coming from this area. I hovered my finger around until I found that the source seemed to be 7U00, a small integrated circuit connected directly to 3U32. I touched the top to feel if it was hot (it was) and the board restarted 2 or 3 times in a row. I made sure I wasn't touching any pins and tried it again with the same result. I've heard that when processors get hot, it sometimes means they are bad, but I don't know if this applies to ICs.
              I searched the guide to see what else I could find about 7U00, and it seems like its a fairly important circuit?? Page 142 says it is a MOSFET driver and PWM generator. The paragraph titled "Voltage Booster" on page 142 says that pin 4 should be 18V. I tried to get a voltage reading on pin 4, and as soon as I touched the probe to it, the board restarted continuously, so much so that I couldn't even get a reading on the pin. Pin 4 is directly connected to 3U32. Coincidence? Maybe.
              This is where I'm stuck. Like I said, I'm pretty inexperienced, so I don't know where to go from here or what to test next. Does it sound like I may be on to something or am I on a wild goose chase? Maybe I'm just causing a short... Any advice is appreciated, I'm here to learn.
              *Full diagram of the main board can be found on page 122; 7U00 and 3U32 are in E2*
              • dskall
                • Oct 2016
                • 2905
                • usa
                #27
                Need some pictures of the area
                • Sly_Boogy
                  • Aug 2017
                  • 4
                  Whoops, image didn't post. Tell me if you can't see it well enough, I'll try and get a better one.
                  • Sly_Boogy
                    • Aug 2017
                    • 4
                    Alright, that picture sucked. These are a little better. There was more of that grayish mark/stuff around the SMD (burned solder?), but it came off when I grazed it with the probe.
                    • Sisko
                      Onkyo-593 No power and now clicking sound
                      by Sisko
                      Hi all!!
                      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                      10-03-2025, 02:18 PM
                    • B0r1s
                      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                      by B0r1s
                      PSU - BN44-00878A
                      Symptoms:
                      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                      A weak clicking sound was coming from the transformer.
                      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                      Progress:
                      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                      01-17-2023, 04:58 PM
                    • slimmy182
                      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                      by slimmy182
                      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                      Looking on google I found this:...
                      01-14-2023, 11:55 AM
                    • nickgronk
                      iMac PowerPC G4 very low sound • Sunflower Model
                      by nickgronk
                      Just picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
                      I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
                      I cannot find any schematics...
                      08-05-2024, 07:04 AM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
